PLEASE HELP!!! VN 750 wont crank backfires out the carbs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 08-18-2010, 03:17 PM Thread Starter
i traded into a 93 vulcan 750 it been sitting for two years at first it cranked just wouldnt idel so i pulled the carbs and cleaned them to do that i took out the wiring harness and air box after getting everything hooked back up i tried crankin it but all its doing is backfiring out the carbs and i dont know what i did wrong please any help
HOLLISTER is offline
post #2 of 6 (permalink) Old 08-18-2010, 04:36 PM
Senior Lurker
Sloppyburpfest's Avatar
I'm not an expert mechanic by any stretch so this may be a dumb question...
Did you connect the sparkplug wires to the correct spark plugs? I worked on an in-line four engine a long time ago and accidentally plugged the wires into the wrong plugs (in the wrong order). When I tried to start that bike it sounded like the 4th of July.
-Sloppy
My Flickr Gallery < Link >
Küryakyn LED battery monitor
R.I.P. Lance328
Sloppyburpfest is offline
post #3 of 6 (permalink) Old 08-18-2010, 05:55 PM
second that......
dariv is offline
post #4 of 6 (permalink) Old 08-18-2010, 06:41 PM Thread Starter
considerin its a v twin and has a duel lead coil one on front for number one cylinder and one in the back for number two cylinder i got that hooked up right i know but yall askin did make me go double check lol
im kinda thinkin electrical or maybe vacumm on the carbs?
But hell im not sure this has me stump
post #5 of 6 (permalink) Old 08-19-2010, 01:18 AM
Did you clean the fuel tank?? It sounds like you may have water in the fuel. You can drain the carbs and check for water. There is a drain screw on the bottom of the carb bowl.
post #6 of 6 (permalink) Old 08-19-2010, 08:48 AM
clock152's Avatar
also check the battery... when mine went to crap it would do everything but start.. to include back fires and alot of other stangness!
clock152 is offline
