Low warm up idle while on side stand - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-02-2010, 04:14 PM Thread Starter
Bandito
Mellow's Avatar
Cold start the bike and put it on the side stand to warm up, give her 50% choke and she idles at about 1500 rpm, after a minute or two I sit on her and bring it upright she roars up to about 2000 rpm, I am not touching the choke or the throttle.
It doesn't do this if I warm it up on center stand.
Is this a common issue? My thoughts are it is a float bowl issue, but the bike runs fine, and does not have any power issues.
1993 Vulcan 750 - SOLD
1996 Suzuki Bandit 600 - Current ride
Mellow is offline
post #2 of 7 (permalink) Old 08-02-2010, 04:53 PM
baldy's Avatar
My 93' does the same thing. Its got 43k on it and never done the carbs. I know that I have to take the carbs apart for a good cleaning tho. Someone else might have the answer.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 7 (permalink) Old 08-02-2010, 05:10 PM Thread Starter
Bandito
Mellow's Avatar
I just did get my carbs rebuilt this past spring, she runs like a top with no power loss issues. If anything it seems like it might be the back cylinder might not be firing as it should, maybe a lack of gas to that right hand carb? On the side stand she is at a pretty good lean to the left side.
Mellow is offline
post #4 of 7 (permalink) Old 08-02-2010, 05:13 PM
baldy's Avatar
Mine does it even when warm. I know I need a couple carb boots as well. That is why I'm running my 01' more.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #5 of 7 (permalink) Old 08-02-2010, 11:47 PM
When you have it on the side stand is your front wheel turned? If it is it can pull on the choke cable..
rnenrnk is offline
post #6 of 7 (permalink) Old 08-05-2010, 05:07 PM Thread Starter
Bandito
Mellow's Avatar
I checked the choke cable and it is not pulling, I tried it with the wheel straight and got the same results.
Mellow is offline
post #7 of 7 (permalink) Old 08-05-2010, 05:32 PM
Columbus, Ohio
jimkonst's Avatar
I hate to say it, but this looks like a good time to use Seafoam, Staybil, or whatever your favorite fuel additive is.
Just for giggles, when it is cold, lean it over to the right, having somebody suport it, start it with the choke, and see if it replicates the problem. If it doesn't, then I would suspect a float sticking on one side only. If it does replicate the problem, I have no idea, unless it is the initank fuel filter covering and uncovering with sludge.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
