Fuel Injection - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 08-01-2010, 07:09 AM Thread Starter
WILLDOGJONES's Avatar
Fuel Injection
Has anyone ever swaped out the carbs for the fuel injection setup. How did it work out? Is there any fuel mileage benifets? Do you need to add a computer to your bike?
WILLDOGJONES is offline
post #2 of 11 (permalink) Old 08-01-2010, 09:41 AM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I'm not nearly as knowledgeable as others here but I have not heard of any fuel injection setup for this bike.
Chris and Shim is offline
post #3 of 11 (permalink) Old 08-01-2010, 09:52 AM
baldy's Avatar
The VN750 was not computerized so it would be about like re-engineering the bike just to put fuel injection on it.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #4 of 11 (permalink) Old 08-01-2010, 11:04 PM
MANIC MECHANIC
vulcanjoe's Avatar
there is a way to turn your cv carbs into fuel injected throttle bodies. The kit is available from the same place I bought my r/r www.roadstercycle.com look down the menu for the cv to tbi kit and read the instructions. the reason I didnt do this is the fuel pump and regulator and the cost but it in theory could be done, with a little work and a lot of money.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #5 of 11 (permalink) Old 08-02-2010, 01:33 AM
JMHO, but if you want fuel injection, it is more cost effective to go for a newer bigger ride.
post #6 of 11 (permalink) Old 08-02-2010, 08:34 AM
baldy's Avatar
X2.
If someone has that kind of money to throw at an older bike might as well get a newer one with Fi.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #7 of 11 (permalink) Old 08-02-2010, 07:11 PM
IronMan750's Avatar
Although this isn't true fuel injection, it's about as close as you'll find within reason. If done right, will make a big difference in power. I installed this on my bike, mainly because of jetting problems with the extreme variations in altitude here (4K - 11k feet!) but will work at any altitude. It's called Intela-Jet. It's simple to install but not necessarily easy. Cost me about $260 (w/shipping) to do it myself. No computer needed. No air induction changes needed! It's an upgraded version of "Dial-A-Jet".
I absolutely love the thing! I can adjust my jetting simply by turning a knob while riding! How cool is that? Anyway, it might be worth looking into. If you want more infor on it, talk to Lon at Thunder Products.
2003
*Battery connected at both ends!
*Real air in the tires
*New Registration sticker
*Seat wiped off
*Low AND Hi beam headlight!
*New #1157 tail light bulb
*Brake pedal still on the right
*Custom valve stem caps made from black plastic!
*Custom built ignition key from Kawasaki
Does anybody really care?
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car"
IronMan750 is offline
post #8 of 11 (permalink) Old 08-02-2010, 11:42 PM
I have read about the Dial-A-Jet before, but will have to read about this Intela-Jet upgrade.
It seems a reasonable price if it works as you say it does.
I don`t have any problem with elevation changes out here on the prairies, but it might be helpful if/when I get a chance to ride through the Rockies in BC.
Thanks for the link.
post #9 of 11 (permalink) Old 08-06-2010, 11:50 PM Thread Starter
Thanks
post #10 of 11 (permalink) Old 07-09-2016, 08:52 PM
I'm looking into getting an intelajet for my VN750. Just a little curious about the install on our bikes. were you able to do a direct connect, or did you have to drill into the bowl? Anything else worthy of note about the install?
Firewhirl is offline
