Fuel/Air troubles - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-30-2006, 07:17 PM Thread Starter
Angry Fuel/Air troubles
I am completely stumped and looking for help. I bought a '93 recently and needed to immediately replace the battery. I rode it home, which was fine, then replaced the battery yesterday when it arrived.
Now, bearing in mind that up to this point the ONLY thing I have done is to change the battery....Now the bike will not run at all unless I keep it under full choke.
I fiddled with the mix screws slightly but didn't want to get em way outta whack. I was going to compare them to my '95 but mine still has the little covers over the screws. I have just about talked myself into gettin past em and seeing for myself but felt I should ask y'all first.
Any ideas?
RepairmanSki is offline
post #2 of 6 (permalink) Old 04-30-2006, 11:58 PM Thread Starter
Aha!
Out of frustration I sat down again and went over every single thing I could think of that would cause (or fix) this problem. Several "might as well, can't hurt" tasks came to mind so I drained the carb bowls and checked for detritus.
There were no obvious signs of dirt or rust but there was a bit of wispy floaters...kinda like backwash. That got the bike to run with the choke off but it still smoked like a demon.
Another "can't hurt" idea was to drop SeaFoam in and cruise up the freeway about 30m each way. The deed is done! smoke is gone, idles practically perfect.
Oh, and I realized that I had done one thing I had not mentioned. The night before my wife and I took our bikes out for a wee ride and she flicked the valve over to reserve for a bit then back to On. Apparently there was enough funky crud hanging out in the reserve pickup tube that settled into the bowls overnight to cause this.
post #3 of 6 (permalink) Old 05-01-2006, 08:41 AM
DMAG's Avatar
Originally Posted by RepairmanSki
Aha!
SeaFoam saves the day again!
Anthony
1985 VN700 (Priscilla) Sold
Helpful Links -->>
Search | Vulcan Verses | VN750 Gallery | VN750 Items on Ebay | Link to VN750.com
DMAG is offline
post #4 of 6 (permalink) Old 05-02-2006, 02:13 AM
Uber Member
you may call it over protective....but atleast everyother week....more like every week i flip to reserve and ride a bit......i go through 3 tanks a week so... but it keeps stuff clean
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 6 (permalink) Old 05-02-2006, 05:10 PM Thread Starter
No doubt Anthony. I admit to being skeptical of the claims on the bottle but the forum convinced me it was worth a shot.
Put in in your oil!
Put it in your gas!
Put it in your injectors!
Put it in your 2-stroke mix!
Use on your breakfast cereal! (okay not really that one)
Still, I was amazed to find that the product claims were met or exceeded by reality.
post #6 of 6 (permalink) Old 05-03-2006, 10:26 PM
it increased my MPG from about 40 to 50...
kornolio is offline
