Idle Adjustment not working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-29-2010, 12:04 PM Thread Starter
nuthouse173's Avatar
Hi All,
I have 94 VN 750,runs great EXCEPT cannot adjust the idle. The Bike runs great but I need to keep it choked about halfway to insure I stay running. If I open the the choke fully the bike stalls. I have cleaned the idle needles and run Seafoam through the Carbs to insure nothing is sticking.
When I try to adjust the idle, nothing chnages no decrease no increase.... could the idle adjustment become stripped?? Or maybe a vacuum leak??
nuthouse173 is offline
post #2 of 6 (permalink) Old 07-29-2010, 12:40 PM
Calif Rider
weh44att's Avatar
I just went out and checked my bike and you can see the shaft just behind the knob turn if it is not stripped. If it does turn, get on the right side of the bike and under where the throttle cables attach at bottom of carbs. You can see a spring that will compress or decompress as you turn the knob on the left. The adjuster may not be connected properly, or not at all
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 6 (permalink) Old 07-29-2010, 08:16 PM Thread Starter
Well thats not the issue....Thanks for reply, I checked the adjustment from the right side of the bike... and was able to see the screw moving and adjusting the throttle the way it should...... The issue now... the idle screw is set all the way in, and I still cant take the choke off all the way. The choke needs to saty on at least half way for the bike to stay running.... Help please!!
post #4 of 6 (permalink) Old 07-29-2010, 08:42 PM
flitecontrol's Avatar
I think the carbs may be dirty. Can't think of anyting else that would require choke all the time, unless the throttle cables aren't adjusted properly. Try Sea Foam in the gas. Initially about 1/2 can in a tank of fresh gas. Then ride it like you stole it.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 6 (permalink) Old 07-30-2010, 03:23 AM
KIMMERLING's Avatar
Ride it like you stole it! X2!
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #6 of 6 (permalink) Old 08-03-2010, 11:43 AM
gun slinger
centurynick's Avatar
mine had a similar problem i was told to rip on it and thats what i did , now it fixed it self . i also added sea foam every time i added fuel
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
