Freakin busted bolts!!!!! AAAARRRGGGGG! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 07-06-2010, 09:23 AM Thread Starter
clock152's Avatar
Ok.. soooo i busted the head off of one of the petcock bolts in the gas tank!... no biggy right???.. wrong.... this sucker is in there for good!...the first easyout extractor... busted it.. got it out .. the extractor that is.. the 2nd one.. snap!!!.. are you kidding me????.. these things are like the hardest metal known to man!.. try and drill one of these extractors out!.. no go!....so now I have a busted bolt with an extractor filler in a bolt hole in the gas tank!.. good times!.. gave up for now.. baught some RTV red and sealed it up useing only one bolt.. probably wont work but its been sitting there cureing for a day now.. gonna try it this evening. maybe.... or jsut pour the gas on the seat and set fire to it....LOL
clock152 is offline
post #2 of 20 (permalink) Old 07-06-2010, 10:07 AM
baldy's Avatar
Yeah the easy out extractors are hardened steel to the point of being brittle and easy to break but can't be drilled. (Go figure) Sometime you can get the extractor/easy out out with a pair of needle nose vise grips if there is some to get hold of. Turn it clockwise and pull a bit as you turn it. As for the bolt...some left hand drill bits and keep increasing the size as you go. It may come out but if you start seeing threads a tap the same size as the bolt will take care of the rest.
If the threads get messed up get some hellocoils<<<(think that is what they are called) that help with stripped out threads or you could go up 1 size on the bolt.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 20 (permalink) Old 07-06-2010, 10:20 AM Thread Starter
clock152's Avatar
Yeah.. I was thinking I would just try and drill the whole thing out to a bigger size and re-tap the hole... the extractor broke to deep to get a hold of.... after I clean all of the RTV off...LOL.
clock152 is offline
post #4 of 20 (permalink) Old 07-06-2010, 10:24 AM
baldy's Avatar
Try useing a pointed punch and tap it in a clockwise direction. It may pop loose. You will make a huge mess trying to drill it out and may wind up needing a new tank.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #5 of 20 (permalink) Old 07-06-2010, 10:32 AM Thread Starter
clock152's Avatar
sounds like I may need to take it to a pro then.
clock152 is offline
post #6 of 20 (permalink) Old 07-06-2010, 10:38 AM
baldy's Avatar
Time and patience and holdin your tongue right is all that is needed. lol
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #7 of 20 (permalink) Old 07-06-2010, 10:39 AM Thread Starter
clock152's Avatar
hahahahahahahaha.. I have little of each it seems.
clock152 is offline
post #8 of 20 (permalink) Old 07-07-2010, 08:46 AM Thread Starter
clock152's Avatar
I just looked at the pics of the tank that someone cut in half... I think I'm screwed.. the bolt screws into a nut that is tacked on the inside of the tank.
clock152 is offline
post #9 of 20 (permalink) Old 07-07-2010, 09:11 AM
baldy's Avatar
If you can get the easy out extractor out you can drill the old bolt out in incraments RE; keep going up a size drill bit and retap the nut as long as you don't go beyond the threads. Im not sure what size the bolt is but don't go any bigger with the drill bit, maybe stay one size below and just get the rest out with a thread tap. Just have to stay streight in the broken off bolt.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #10 of 20 (permalink) Old 03-21-2011, 09:32 AM Thread Starter
clock152's Avatar
Update on this issue....ended up JB welding the petcock to the tank...held well for a while.. but I am guessing that there was to much vibration or something.. she leaks like mad.. guess I am gonna be buying a tank.. arg!
clock152 is offline
