Phantom Gas Solved 4 Me - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-01-2010, 02:13 PM Thread Starter
Hey all! I've followed all the phantom gas threads for a while. When I had scarlet apart for the fix from the accident I totally cleaned & prepped the tank. I made sure that air vent was clean. I then dismantled my gas cap to inspect & clean it. Blew air through all the little holes I couldn't get to & removed the floppy detached gasket material that's in there. I'm certain that was my culpret. Hell, I've even got my reserve back. Sweet! Worth checking out if your having the phantom gas issue.
post #2 of 5 (permalink) Old 07-01-2010, 04:12 PM
Gemguy's Avatar
Does this mean that you're the new ghost buster?
~VROC~ # 389
Gemguy is offline
post #3 of 5 (permalink) Old 07-13-2010, 03:56 PM
artemis_f0wl's Avatar
Send a message via AIM to artemis_f0wl Send a message via Yahoo to artemis_f0wl Send a message via Skype™ to artemis_f0wl
I've cleaned my cap out and the vent line as well, but I'm still having issues. When you mention "removed the floppy detached gasket material that's in there" are you referring to the red-ish circles that act as backflow stops?
I have the smallest tank of anyone I ride with and they like to cruise a little fast so my mileage is an issue, having this problem makes it even worse- almost embarrassing sometimes.
NIL ILLEGITIMUS CARBORUNDUM
Phil aka Art
"Vanessa"
1995 VN 750 (bought as 2nd owner 11/2008)
26,440 miles
Stator replaced (55 Days!)
V&H Cruisers
Relocate rear turn signals
Highwayman Saddlemen bags
Wingerline Highway bars
Ear Shave
Rejet carbs
R/R relocate
Kuryakin ISO Duallys all around
HD Heritage seat
12" ape hangers
To Do:
Some sort of new grips
Mirrors
Paint Job- should I do it myself?
artemis_f0wl is offline
post #4 of 5 (permalink) Old 07-13-2010, 05:14 PM
baldy's Avatar
Some of the out of gas symptoms can also be caused by crud floating around your tank.
When I got my 01' I took the tank off and the petcock off and big chunks of stuff came out. I'm thinking if that is floating around and you get vaccum from the carbs and it can suck that crud onto the screens and stop fuel flow or at least slow it down enough to make the bike act up and when the bike shuts off the crud comes off and your off again. Also if you don't use the reserve much the water doesn't get perged from the tank either and a shot of water will kill a bike or slow it down anyways.
I know seafoam works on water and does a hell of a cleaning, but it doesn't totally get rid of it with this new ethynol mix because seafoam has been out long before ethynol and isn't really formulated to take care of the new problems. This is why I use the K100 mg it is formulated for the ethynol/fuel mix and makes water burn.
Also as I mentioned in previous threads, when I am on the highway I put the bike on reserve to get rid of any water that may be in there. The higher revs and steady throttle will keep the bike from stumbling if I get a good does of water.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #5 of 5 (permalink) Old 07-13-2010, 05:24 PM
The vaccuum hose that goes to the petcock from the carb has caused a problem simular to the phantom problem. A small leak in the hose will keep the feul from flowing into the carbs.
