Low grade fuel......also high altitude - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-25-2010, 01:30 PM Thread Starter
Hi,
Has anybody used these bikes with low grade fuel? I understand the engine runs at quite a high compression ratio. Will this cause problems if the bike is used with low grade/low octane fuel?
Also, at what altitude might I start to find problems with the bike?
Cheers,
Gabriel
gabrielwalton is offline
post #2 of 12 (permalink) Old 06-25-2010, 01:52 PM
The vn750 has a 10.3:1 compession ratio, and is designed to run on regular grade, 87 octane gas. This seems to me, to be quite high compression for regular gas, but I have seen reports here of the vn750 running worse on higher octane mid grade or premium gas.
What grade/octane level do you expect to find on your adventure in Asia? Lower octane will cause pre-ignition (pinging) at some point.
What altitude will you reach too? If your bike is tuned to run near sea level, the thinner air at altitude will have it running rich I think.
Sorry I can`t offer any any more specific answers.
post #3 of 12 (permalink) Old 06-25-2010, 03:50 PM
dirtrack650's Avatar
I ride up to 4,300 feet in my area. The bike runs and starts ok, but there is a loss of power. Higher octane may help?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 12 (permalink) Old 06-25-2010, 04:15 PM
DT
Higher octane would make it worse, because higher octane gas is harder to ignite.
Use regular gas at all times. I think once you get above 7000 ft you might have some issues.
Do a google search for " Dial a Jet " ...a system that lets you increase or lower your carbs fuel to air ratio with a turn of a knob.
post #5 of 12 (permalink) Old 06-25-2010, 05:50 PM
Mushu's Avatar
Send a message via MSN to Mushu
I ride here 7,200 ft in Mexico city and... uhmmm, how can I put it?, here the gas is really very bad... piss quality bad. Not much running issues, some hesitation going full throttle but not much more so I think you will be ok
93 VN750
R/R Relocation to the front
Pirelli MT66 Tires soon to be mounted (only after 14 years...)
Mushu is offline
post #6 of 12 (permalink) Old 06-26-2010, 03:55 PM Thread Starter
Thanks for the info All. I guess its looking good if I have to use low grade fuel....and if I have to go up high. These will be things I wont be doing often.....and wont be pushing the bike either. Just glad to know the bike can handle it if it needs to.
post #7 of 12 (permalink) Old 06-26-2010, 04:46 PM
IMBoring25's Avatar
The low octane and the altitude go together. Since the ambient air pressure is lower at altitude, for a given engine, the combustion chamber pressures are also lower, so pre-detonation is less likely and a lower-octane fuel can be used.
IMBoring25 is offline
post #8 of 12 (permalink) Old 06-26-2010, 10:44 PM
Warlord247's Avatar
I use 85 octane (regular) and ride at 5280 ft. (Denver) and have no problems.
"The Mistress".
1985 VN700A1
MODS:
New stator
My version of the Marbleing
New paint and trim
New oversized front tire
Degoated
Iridium Plugs
New grip and lever covers
New(er) Ignition switch
Waiting on:
A good ride
As always:
Wanting attention at all times.
Why should I act my age, I am an ADULT!!!!!!
Warlord247 is offline
post #9 of 12 (permalink) Old 06-26-2010, 11:02 PM
KIMMERLING's Avatar
I am currently reading Jupiter's travels by Ted Simon...in that book he rides a Triumph 500 with "low compression pistons" that run much smoother than stock and work well for poor fuel encountered in his travel. Any applicability to a Vulcan 750?
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #10 of 12 (permalink) Old 06-27-2010, 01:12 AM
Actually, higher octane has a longer burn time. The loss of power may be compensated with 92+ octane. Same principle as piston airplane engines (108+ fuel)
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
