ear shave question... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-12-2010, 09:45 PM Thread Starter
I put the V&H pipes on today, and am looking at doing an ear shave and coaster in the near future. My question is, has anyone done the ear shave and replaced the stock intake with a single air filter?
dariv is offline
post #2 of 6 (permalink) Old 06-12-2010, 10:07 PM
Yes someone put a dual inlet filter underneath the gas tank where the air box is now.and they posted it on here I just don't know who it was.
post #3 of 6 (permalink) Old 06-13-2010, 12:38 AM
YES it has been done... I did it... and here is a write up of some one else... although I did mine for even cheaper than his... I took a piece of 16 guage steel and cut it to the shape of an oval filter to make both a top and bottom for the air cleaner, I then cut two round hols in the bottom plate for the stock carb boots to breath through, and one hole for the breather hose. total cost of parts was $16 bucks... I will look for the part number on the filter in the AM... its in my garage some where.
Air Filter
Product Line: NAPA Small Engine
Part Number: SME 708355
Price:
Price
Unit
19.29
Each
Availability:
Available Now
Features & Benefits Meets Or Exceeds OEM Specifications; Made In The USA
Warranty 2 Year Limited on Manufactures Defect in Material or Workmanship
Attributes Air Filter Bottom I.D. (Inches) : 8.75"
Air Filter Bottom I.D. (mm) : 222.25 mm
Air Filter Bottom O.D. (Inches) : 3.75"
Air Filter Bottom O.D. (mm) : 95.25 mm
Air Filter Height (Inches) : 3.25"
Air Filter Height (mm) : 82.55 mm
Air Filter Length (Inches) : 5.5"
Air Filter Length (mm) : 139.7 mm
Air Filter Style : Cartridge
Air Filter Width (Inches) : 2.75"
Air Filter Width (mm) : 69.85 mm
O.E. # : 110132114
Original Equipment Series : Kawasaki
post #4 of 6 (permalink) Old 06-13-2010, 10:58 PM
baldy's Avatar
Is there a Y manifold pipe that can be used to vent the carbs to one side and put a filter there.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #5 of 6 (permalink) Old 06-14-2010, 12:22 AM
i didn't use a filter, just ran the crank case l lines together then ran one to the middle of the filter. as for the "Carb" vent line, I just ran it back to where the emissions crap used to be. I did have to re-jet though...
post #6 of 6 (permalink) Old 07-07-2010, 12:55 PM
If I understand you right, you don't mean to vent per say but to draw air in... from the right hand side more or less... there isn't a stock application for a Y Minifold, but one could be made very easily... then run a single pod filter or a rig up a mount for a HD looking filter.. but then the ears have to come all the way off.
