cvk34 vn750 1990 carb alternative - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 06-06-2010, 05:38 AM Thread Starter
Hello fellow riders.
any ideas on a alternate set of carbs i could use for a vn750 1990 as my origanals have been damaged. due to the year of the bike and here in the uk there do not seem to be many around
Regards Neilhttps://www.vn750.com/forum/images/smilies/baby.gif
taylor is offline
post #2 of 14 (permalink) Old 06-06-2010, 12:18 PM
MANIC MECHANIC
vulcanjoe's Avatar
thats all that fit i have heard of fuel injection kits that use the carb body as a throttle body but that usually costs more than the bikes do.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 14 (permalink) Old 06-06-2010, 02:00 PM
dirtrack650's Avatar
Someone here needs to make a manifold to mount one carb.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 14 (permalink) Old 06-06-2010, 05:34 PM
I don't know if you are aware or not but you can use carbs from 85-06, it doesnt have to be a 1990.
cdaddy is offline
post #5 of 14 (permalink) Old 06-06-2010, 08:14 PM
flitecontrol's Avatar
They show up fairly often on ebay.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 14 (permalink) Old 06-07-2010, 05:18 PM Thread Starter
Thanks for that what about using another make of carb or from other makes of twins ?
taylor is offline
post #7 of 14 (permalink) Old 06-07-2010, 09:28 PM
I've never heard of one, but maby someone else will chime in.
cdaddy is offline
post #8 of 14 (permalink) Old 06-09-2010, 11:48 AM Thread Starter
Thanks for that info. i was also wondering if there is any other make of carb from other bikes taht could be used regards
Neil
taylor is offline
post #9 of 14 (permalink) Old 06-09-2010, 12:05 PM
fergy's Avatar
Neil, it is pretty unlikely that any other pair of carbs would be a straight bolt on swap. Maybe someone who has worked on many more bikes than I can shed some light on that, but I'm doubting there will be a clean fit, when you consider the entire combination of variables, cables, choke, manifolds etc. besides the different jetting etc.
There are enough of these bikes being parted out constantly that you'd probably have better luck finding this exact set than going through what ever it might take to convert some from another model. Just my .02~
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #10 of 14 (permalink) Old 06-09-2010, 07:01 PM Thread Starter
Hi Fergy
There are not many here in the uk i did see some on ebay in the states but were not cheap
Will just keep looking
Regards
Neil
taylor is offline
