Re-jetting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-26-2010, 09:08 AM Thread Starter
Re-jetting
This is a segue of a previous thread under Engine-Exhaust-Cooling started by vulcanpappy called 'V&H Cruzers' that has evolved into a conversation about re-jetting.
Is there a rule-of-thumb for what jets should be used at a given altitude? In other words, what jets would be used at:
Sea level
500' above SL
1000' above SL
etc...
What size jets are factory installed?
What other considerations determine what jets should be used?
VoIPDoc is offline
post #2 of 5 (permalink) Old 05-26-2010, 10:17 AM
The Professor
lance328's Avatar
In most cases rejetting is not needed when installing V&H exhaust but you will need to turn the pilot screws out 3.5 turns.
If rejetting is needed then I suggest using the combination I gave Jerry and others, it wil work @ any altitude.
#40 Pilots
#135 Mains
2 Turns out on the pilot screws
If you do an earshave then that's a different ball game.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 5 (permalink) Old 05-26-2010, 10:20 AM Thread Starter
Oops...my bad.
When doing an earshave, is there a rule-of-thumb for what jets should be used at a given altitude?
VoIPDoc is offline
post #4 of 5 (permalink) Old 05-26-2010, 10:39 AM
The Professor
lance328's Avatar
Originally Posted by VoIP Doc View Post
Oops...my bad.
The basic rule of thumb is more fuel @ sea level and less @ high altitude.
As far as I know there is no chart to tell you what combination to use. For me I used 1000' as a baseline since I know what combination works. The jet combination also depends on the type of intake filters and if your exhaust is open or baffled.
Since I have done sooooo many different jet combinations around the world for different conditions and setup's I only need to know three things.
1) Elevation
2) Type of filters
3) Type of exhaust
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 5 (permalink) Old 05-26-2010, 12:54 PM
1992 VN 750
bordolover's Avatar
1. 7000 above MSL
2. Stock
3. V and H Cruzers
1992 VN 750 / 18,100 miles
V and H Cruzers
Earshaved and sheared
110/90 and 170/80 Metzeler 880s
AGM Battery
TPE Stator
Clear Alternatives LED brakelight
Saddleman Explorer Seat
Kurakyn Levers
VN750.com Grill cover
SCP Coasters
Iridium plugs
MOSFET R/R
bordolover is offline
