carb diaphrams will not open - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-24-2010, 11:07 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
Question carb diaphrams will not open
well i finally got the bike back together. got the fatboy seat mounted decided to take it on its first test ride since the engine reinstall. first i balanced the carbs and then took off she felt like a beast in the parking lot then at more than half throttle it fell on its face. upon more careful examination i found that when you crack the throttle the diaphram does not pull the piston up which does not move the needle off the main jet. starving it for fuel i removed the carbs checked the hole in the pistons the last time i put them together i put the spring holder over the hole and it wouldnt open i checked this again not the case. so i am lost any suggestions.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #2 of 5 (permalink) Old 05-24-2010, 11:14 PM
The Professor
lance328's Avatar
Sounds like the piston diaphram is not seated properly causing a leak, how old are the carbs?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 5 (permalink) Old 05-25-2010, 08:22 AM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
they are original. i thought that too but it ran fine last season (I know winter is a long time to sit i will take them apart today and try again)
34k so far
coastered
spline lube
TPE stator
post #4 of 5 (permalink) Old 05-25-2010, 08:37 PM
Crobins365's Avatar
Ditto what Lance said. If the diaphragms aren't seated right, you'll have exactly the problem you describe (basically, think about trying to use a straw that has a hole in it - all that suction, but a lot of it is wasted on pulling air through). An easy way to check is to push the piston up with your finger and listen for a nice "whoosh" sound - there should be slight resistance if you've got a good seal.
Lance'll kill me for saying this, but on older diaphragms, I have used a tiny bit of sealant (INSIDE the groove where the diaphragm is seated) to ensure that the seal stays tight. The risk, of course, is that you put too much sealant and pull it into your carb, but I've not experienced that to date. Just a wee bit of sealant...enough to make sure the diaphragm sits where it's supposed to until you get the cover on.
C
Crobins365 is offline
post #5 of 5 (permalink) Old 05-25-2010, 09:20 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
Lance was right i bricked on both of them i was in a hurry when i put them back together. but now due to todays disassembly I am in need of new needle shims (long story)either way i put it back together without them and bingo there she was. thanks lance and cindy
34k so far
coastered
spline lube
TPE stator
