Stumbling at mid throttle to WOT - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-24-2010, 12:09 AM Thread Starter
Exclamation Stumbling at mid throttle to WOT
Just finished reinstalling my carbs today after a good cleaning, and took the bike for a short ride. The bike seems to be running much better than before the cleaning.
Now, however, I'm dealing with another issue. A few minutes into the ride I attempted to push the bike a little, to no avail. In any gear, the bike is fine when using 0 to mid throttle. The problem begins under harder acceleration. The best way to describe what the bike is doing is stumbling/bogging down/sputtering. It seems comparible to an uneven two step.
What could be causing this issue?
Ideas that I had are...
a problem with the floats or a float causing the float chamber/jet chamber to not fill with fuel correctly
a problem with the main jets
I'd appreciate any input or past experience! I've searched as much as I can handle, and am not coming up with any solutions, nor do I have a solid plan of attack at this point.
Thanks!
uuarx is offline
post #2 of 10 (permalink) Old 05-24-2010, 12:22 AM
flitecontrol's Avatar
Did you get the hose that goes into the right ear (air filter housing) connected to the carb properly? If not, it can cause symptoms similar to what you describe. Ditto if the hose bottoms out on the inside of the housing. Cutting the end of the hose at a 45 degree prevents bottoming out.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 10 (permalink) Old 05-24-2010, 12:26 AM
KIMMERLING's Avatar
or do the earshave! it rocks!
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #4 of 10 (permalink) Old 05-24-2010, 01:21 PM
Tero 2010
Hello. I am a new member. Since you are dicussing carbs, do I need to rejet if I get the V and H exhaust system? Thanks Tero
tero2010 is offline
post #5 of 10 (permalink) Old 05-24-2010, 02:51 PM
fergy's Avatar
Usually no. If you live on top of a mountain, maybe. What's your altitude?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 10 (permalink) Old 05-25-2010, 10:13 AM
Tero 2010
Good Morning, I am at 500-1000 ft. I am in Paso Robles, CA. Hot and dry most of the year, but only 45 mins from Morro Bay.
tero2010 is offline
post #7 of 10 (permalink) Old 05-25-2010, 10:16 AM
Tero 2010
Good Morning, I am at 500 ft. On the central coast of CA. Usually hot and dry, but only 45 mins from Morro Bay.
tero2010 is offline
post #8 of 10 (permalink) Old 05-25-2010, 10:17 AM
fergy's Avatar
You should be fine with stock carb jets and V&H exhaust then...
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 10 (permalink) Old 05-25-2010, 10:53 AM Thread Starter
Thanks for the actual responses to my question. I was able to get the problem solved. It turns out that it indeed was the carb vent line bottoming out against the back of the right airbox. I got it cut at an angle and repositioned it under the gas tank. The bike is now running better than ever.
uuarx is offline
post #10 of 10 (permalink) Old 05-25-2010, 11:07 AM
fergy's Avatar
Sweet!
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
