rich?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-23-2010, 02:16 PM Thread Starter
Rook's Avatar
rich??
Last night I succesfully completed my coastering and ear shave and it seemed to run fine on a test ride around town, but leaving for work this morning I noticed that full choke will now kill the engine and it seems to smell a little gassy. Also, on the highway it started surging after about 5 miles at 80mph and onr cylinder breifly cut out.
I set the pilot screws at 3 turns out per Lance's instructions, but I think I need to crank them back in about 1/2 turn or so. Any thoughts?
Rook
Conway, AR
VROC # 30581
WBRA #90237-1
2009 1700 Nomad (mine)
2003 VN750 "Prozac" (now hers)
25'000 miles at purchase
Ears shaved
Cobra exhaust
So, why is a raven like a writing desk?
Rook is offline
post #2 of 6 (permalink) Old 05-23-2010, 06:59 PM
KIMMERLING's Avatar
I have no clue. I just went on my first long ride after the earshave was completed yesterday and it seemed to run great throughout the throttle. My screws are 3 turns out like Lance told me to. I look forward to the answer to your question. Maybe too much fuel?
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #3 of 6 (permalink) Old 05-23-2010, 07:52 PM
Did you place the carb vent hose out of the wind. If you get air pressure into that hose it will cause the engine to surge. Mine is connected to the nipple that is directly under the fuel tank.
post #4 of 6 (permalink) Old 05-23-2010, 08:53 PM
The Professor
lance328's Avatar
With the earshave you no longer need full choke because of the lerger jets. 3 turns is just a starting point, you will need to check the plugs and adjust the pilot screws accordingly.
If the fuel vent was the cause it would have started around 45-50 mph not 80 mph, and not 5 min @ 80 it would have been around 1 mile or less.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 6 (permalink) Old 05-24-2010, 03:11 PM
Bandito
Mellow's Avatar
I had to turn my screws to 2 turns out on the back cylinder, 2.5 was running to rich.
1993 Vulcan 750 - SOLD
1996 Suzuki Bandit 600 - Current ride
Mellow is offline
post #6 of 6 (permalink) Old 05-25-2010, 01:01 PM Thread Starter
Rook's Avatar
Upon more in depth examination I found not only a fuel leak but both lines were kinked. Pulled the tank, fixed the leak, adjusted/ re-routed the fuel lines. Had to drop the idle down a bit after that, but the plugs look good so I'll run it a while and check'em again
Rook
Conway, AR
VROC # 30581
WBRA #90237-1
Ears shaved
Cobra exhaust
Rook is offline
