carb question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-19-2010, 12:29 PM Thread Starter
Ford
Send a message via AIM to dbking321
carb question
If i remove my carbs to clean them do I have get them re synced?
dbking321 is offline
post #2 of 5 (permalink) Old 05-19-2010, 12:42 PM
Gemguy's Avatar
You betcha. It's not that big a deal if you have the right equipment but if you are going to do a thorough cleaning and you remove the carbs from the bike you will definitely have to reset them to work in unison.
~VROC~ # 389
Gemguy is offline
post #3 of 5 (permalink) Old 05-19-2010, 02:34 PM
Calif Rider
weh44att's Avatar
Go to the threads on syncing the carbs, in the search vn750. These will give you the different ways to do it yourself. I used the two bottles system, this way you have more time to adjust carbs before the you have to shut the bike off. The tube on a yard stick, many easily suck all the fluid into the cabs, before an adjustment can be made.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #4 of 5 (permalink) Old 05-19-2010, 06:13 PM
Rook's Avatar
use Seafoam. Can't say I'd be too worried about sucking that into my carbs
Rook
Conway, AR
VROC # 30581
WBRA #90237-1
2009 1700 Nomad (mine)
2003 VN750 "Prozac" (now hers)
25'000 miles at purchase
Ears shaved
Cobra exhaust
So, why is a raven like a writing desk?
Rook is offline
post #5 of 5 (permalink) Old 05-20-2010, 09:16 AM Thread Starter
Ford
joy i didnt want to have to do that
