Bike is slow to drop to idle - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 24 (permalink) Old 05-18-2010, 01:02 PM
Yes, it could also be leaking diaphrams. (I hate CV carbs) The part between the carb and the engine is called the manifold. It is supposed to be air tight, and completely sealed on both ends. If gas is leaking out, air could also leak in. The gas leak could have been caused by sticking floats on needle valves not sealing well, which could have corrected themselves with use. There might still be a small problem, or it might just be leaking gas when the choke is on at startup. But in any event, you have an air leak between at least the rear carburetor and head, which can cause all sorts of running problems. You can tighten the clamps and see if that helps, if not, you will probably have to replace the manifold.
As for the carbs themselves, before pulling them off and taking them apart ( taking them apart is easy, removing and reinstalling them is very tedious), try draining the gas out of them, disconnecting the fuel lines at the petcock, filling the carbs up with Seafoam through the fuel lines, and letting them soak for 24 hours. This might get rid of any remaining gunk in there that could be interfering with the floats, needle valves, and jets. It's worth a shot before pulling the carbs. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #12 of 24 (permalink) Old 05-20-2010, 03:21 PM Thread Starter
VulcRider24's Avatar
Heres an update:
I was riding down the highway with the engine completely up to normal operating temperature, when all of the sudden I started losing power. The Tach started bouncing up and down and the bike was lurching. I immediately took the first exit I could and the problem seemed to go away, it was idling fine too. Later (about ten minutes) I was slowing down to at a stop light when the engine died while it was still at about 2000 RPMs. Also, it is still very slow to lose RPMs if I pull the clutch out as I come up to a stop. The entire ride home the bike was not running right and the tach needle and engine seemed to be all over the place.
I tried looking for the plugs that cover the screws but couldn't seem to find them. What side of the bike are they on exactly?
I hope this helps narrow down my problem. Could it be vapor lock? I did fill up on gas before the engine warmed up.
1994 Kawasaki Vulcan 750 named Jinba Ittai (Japanese for "Horse and rider in perfect harmony").
Jardine Pipes
Splines Lubricated
Painted Instrument Bezels
Headlight Visor
Chrome engine guard
Leather Fork Bag (contents: Pressure gauge, tools, and a Book of Psalms)
Yuaso MF AGM Motocross battery
Kenda Kruz Front tire
Duro Boulevard rear tire
"Buy the ticket, take the ride."
-Hunter S. Thompson
VulcRider24 is offline
post #13 of 24 (permalink) Old 05-20-2010, 03:29 PM
fergy's Avatar
The tin plugs are from the factory, sealing the air mix screws that are located next to the vacuum ports, one on the outside of each carb. In other words, there's one on the left side of the bike and one on the right, located on the visible side of each carb. If the plugs have been removed, then you'll see the small brass air mix screw ends with a slot in them for a screwdriver to adjust them.
If your tach was bouncing around while the issue showed up, I would check your front coil connections, or your ignition switch for something loose. I don't think the fast idle problem is necessarily related to the stumbling engine issues you experienced in your last post. Hard to say, but I feel like it is two different issues.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #14 of 24 (permalink) Old 05-20-2010, 05:59 PM
kay
carbon unit
kay's Avatar
Originally Posted by VulcRider24 View Post
Do you think a carb overhaul is in order?
Yes, I do
2010 Triumph Speedmaster
1995 Vulcan750
1989 XT350
M880
1959 M38A1
kay is offline
post #15 of 24 (permalink) Old 06-03-2010, 02:24 AM Thread Starter
Took my bike to a trusted mechanic. His first diagnosis is that my low idle jet is clogged, which makes perfect sense. When my bike would start acting up, a vacuum was created in the carbs where it shouldn't be which caused my bike to fire on one cylinder. This could explain why my bike would be so slow to drop to idle, why it was sporadic, and why it would lose power at random times.
My mechanic will be pulling the carbs, cleaning them, and checking for other mechanical issues (I'm keeping my fingers crossed lol).
If any of your BS detectors went off on any of this initial diagnosis, please come forward. My mechanic was a certified Car Mechanic but got out of the field because he likes working on bikes much more. He mainly only works on friend's bikes and I have heard outstanding reviews of his abilities. I'll be sure to keep you posted on progress and thank you for all of your help thus far.
Jardine Pipes
Splines Lubricated
Headlight Visor
Chrome engine guard
-Hunter S. Thompson
post #16 of 24 (permalink) Old 06-03-2010, 03:39 AM
KIMMERLING's Avatar
I recommend seafoam frequently as a preventative measure.
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #17 of 24 (permalink) Old 06-05-2010, 07:03 PM Thread Starter
Ok, my wrench pulled and cleaned the Carbs and found them to be spotless and in perfect working order. His next suggestion is that it may be by Cam chains. Could my tensioners have crapped out? I do not notice any knocking whatsoever when the bike is running. Could this be that? Or could it be Electrical? My bike has over 25,000 on it, is my stator finally going?
Jardine Pipes
Splines Lubricated
Headlight Visor
Chrome engine guard
-Hunter S. Thompson
post #18 of 24 (permalink) Old 06-05-2010, 07:24 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Get a New Wrench that knows what he's doing..........This one is just shooting in the Dark and will have your Bike in More Problems & $$$$$$$$,
And still not have Your Bike Fixed.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #19 of 24 (permalink) Old 06-05-2010, 07:27 PM
flitecontrol's Avatar
You can do a search for stator test or check here on the forum and get the procedure. Believe it's also in the service manuals.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #20 of 24 (permalink) Old 06-05-2010, 07:32 PM Thread Starter
Is it very common for the Cam Chain to fail or slip on our bikes?
Jardine Pipes
Splines Lubricated
Headlight Visor
Chrome engine guard
-Hunter S. Thompson
