Wont stay running after start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-16-2010, 09:28 PM Thread Starter
2003 VN750 with 14,000 miles
2 months ago the weather allowed me to take a spin and fill up the tank with fresh gas
About a month ago I went out to run the bike and after bringing it up to temp I shut it down. The next day I noticed gas dripping from the carbs. It looked to be the choke plungers. I pulled the carbs and replaced the plungers. I also wiped down the carbs and cleaned up any varnish or grime I could see, I didn’t disassemble or rebuild anything.
I finally got everything back together and changed out the coolant while I was at it. Now I have some issues.
The bike will start run for 60 to 90 seconds start to idle down and then just die. Its hard to restart but gets better If I let it sit a bit. When I do get it started some times it sounds like only one cylinder is firing for a few seconds. I checked the carbs and they have fuel in the bowls after it shuts off. It also seems like the higher the idle the longer it runs.
I have fresh gas with sea foam in it now and ran it for 5 or 6 times today trying to figure out what’s going on. Im going to try a carb cleaner flush out as soon as I can. I did notice the vacume at 2000 rpm was only 0- 5 inHg and bouncing rapidly between the two…is this normal should it be more steady?
Thanks for any and all help
Ron
rhamski is offline
post #2 of 5 (permalink) Old 05-17-2010, 07:40 PM Thread Starter
update:
After sitting overnight I drained the carbs and removed the drain screw to shoot carb cleaner up into the float bowl. I did both sides.
I removed the air cleaner elements, they looked dirty so I cleaned the foam and put them to the side to dry.
I pulled the plugs, which had no more than 3000 miles on them, for inspection and noticed they were carbon coated, not enough to be a primary culprit but enough that I cleaned them all up.
based on the plug condition and for fun I checked the F/A screws and found them out about 6 turns, I reset them to 3 turns out from full in.
I started the bike up with the choke open enough to hold a 2000 rpm idle, it sounded good and strong. I sprayed some carb cleaner into the air box a few times letting the idle ramp up 500 rpm, letting the bike run a bit and them hitting it again. I did this about 8 times with just a short burst of cleaner each time.
The bike ran for about 5 minuets and then started to die, it ran long enough for the temp gauge to get just past the second hash mark into the normal range.
I broke for a quick dinner.
I returned and started the bike right up, it took a little choke to keep it going and it sounded like one of the cylinders was not firing. A little throttle got things right with that.
After about 3 minutes it started to die again. I used the throttle to rev up to 2500 - 3000 rpm. and the bike ran fine, as long as I held it over 2500 rpm. I ran it until the cooling fan came on and then let off the throttle and it revved down normally and as it fell below 2000 rpm it died.
Should I keep cleaning as I did or is this a definite problem that requires a carb pull and rebuild?
rhamski is offline
post #3 of 5 (permalink) Old 05-17-2010, 08:01 PM
The Professor
lance328's Avatar
Pilot jets are clogged, remove carbs and clean.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 5 (permalink) Old 05-24-2010, 01:50 PM Thread Starter
Just a quick update:
while I know i should have pulled and cleaned it was such a pain the first time I thought I would clean in place and see how it goes.
Day 1, clean fresh fuel with seafoam, ran for a while. Drained carbs and did a big flush out with carb cleaner.
Day 2, more flush out...running longer
a few days later and one more flush out, running good...went for a nice run around town.
Sat for a week with good gas and seafoam. Started right up and dident die out when the choke was off. i was detailing and cleaning so I dident go for a ride but I think Ill start comutting again(80 mile round trip) and see how it goes.
rhamski is offline
post #5 of 5 (permalink) Old 05-24-2010, 02:48 PM
fergy's Avatar
I think you might have gotten lucky with the seafoam getting into the pilot jets and actually clearing them out. The pilots meter your fuel when the bike is idling and just above idle until your other jets kick in and the pilots don't have much to do with the mix. Since it ran pretty good until it dropped below 2000 rpms, (right about when your pilot jets take over) it was obvious that they were clogged. Seafoam is wonderful stuff. Glad for you!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
