flooded float? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 05-07-2010, 10:35 PM Thread Starter
flooded float?
So I finally got my carbs taken apart and they were pretty filthy. Not too much of a suprise as bike is 25 years old. The suprise was one of the floats is half full of liquid. Any thoughts on this?
cdaddy is offline
post #2 of 15 (permalink) Old 05-07-2010, 10:48 PM
hillbilly's Avatar
it mist have a hole in it you need to buy another or it will never run right they should b pretty cheap
If It's Got Wheels I Can Drive It
If It's Got Hair I Can Ride It
K and N Pods
12 inch Aps
Handle Grips
Dual Break Lines
House Of Colors Candy Apple Red
Lowered
Road Pegs
Jetted
Coasters
Custom Exhaust
Red Plug Wires
Neons
Custom Switch Panels
Harley Turn Signals(Coming UPS)
Red Hoses
Removed Tach
Removed Speedometer
hillbilly is offline
post #3 of 15 (permalink) Old 05-08-2010, 05:30 PM
If you can't find one try a thin layer of jb weld. That is after the fuel have evaped out of it. Or use solder gun and solder the hole up.
post #4 of 15 (permalink) Old 05-08-2010, 05:34 PM
flitecontrol's Avatar
I believe niterider means use heat from a soldering gun to melt/seal the hole area on the float. Solder will melt through the plastic on the float. If you got the JB Weld route, I'd recommend a Q-tip and alcohol to remove all traces of gas. If there is any, the repair probably won't stick.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 15 (permalink) Old 05-08-2010, 05:38 PM
I never had one apart. I thought they were metal. But that is a good idea too.
post #6 of 15 (permalink) Old 05-08-2010, 05:51 PM
I believe they are plastic. If you aren't real careful, you'll just melt a bigger hole in it with the soldering gun!
"Black Beauty"
Old Blue
post #7 of 15 (permalink) Old 05-08-2010, 05:54 PM
MANIC MECHANIC
vulcanjoe's Avatar
they are plastic not too expensive i think i payed 30 each 2 years ago
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #8 of 15 (permalink) Old 05-08-2010, 05:58 PM
Is that 30$????
post #9 of 15 (permalink) Old 05-08-2010, 06:00 PM
hillbilly's Avatar
you can solder the hole i have done it before it wont melt it just be careful
K and N Pods
12 inch Aps
Handle Grips
Dual Break Lines
Lowered
Road Pegs
Jetted
Coasters
Custom Exhaust
Red Plug Wires
Neons
Red Hoses
Removed Tach
Removed Speedometer
post #10 of 15 (permalink) Old 05-08-2010, 06:11 PM
MANIC MECHANIC
vulcanjoe's Avatar
yes 30$ each at the local kawasaki dealer the float valves i bought on ebay the were for a harley but only 10$ for the pair
34k so far
coastered
spline lube
TPE stator
