Aaarrrrfggggghhhhh - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 27 (permalink) Old 05-07-2010, 10:34 PM Thread Starter
Aaarrrrfggggghhhhh
Man, I need to slow down. I was getting so pissed today. My $1.00 bike won't start! It has fired up a couple of times for about 2 seconds then shuts off. All kinds of annoying things. The back plugs are wet; but nothing drains out of the bowl needle/drain. The front plugs are dry; but open the float needle drain and fuel pours right out...? And no, I'm not mixing the two up. Also, the starter just sucks. I took it apart and cleaned it out with brake clean; it helped a little but it kills my brand new battery in 4 or 5 cranks. Haha: that's the first starter I've ever pulled off a bike! I didn't know the OIL would pour out when you remove it!! Lesson learned.
Also, thanks for the tank cleaning advice guys!! "The works" toilet bowl cleaner instantly took off all the rust inside and left it shiny like new! I then coated it with Seafoam and it looks great.
So for now, I used a giant syringe to put a bunch of Seafoam into both fuel hoses to hopefully fill the bowls and also into the throttle body itself. I'm going to let that soak all night and see what happens. I really really want this thing to run!! I need to be patient!
________
extreme vaporizer review
AirForce1 is offline
post #2 of 27 (permalink) Old 05-07-2010, 10:46 PM
hillbilly's Avatar
i know how you feel mine seemed like it will never get straightened out they can be a pain
If It's Got Wheels I Can Drive It
If It's Got Hair I Can Ride It
K and N Pods
12 inch Aps
Handle Grips
Dual Break Lines
House Of Colors Candy Apple Red
Lowered
Road Pegs
Jetted
Coasters
Custom Exhaust
Red Plug Wires
Neons
Custom Switch Panels
Harley Turn Signals(Coming UPS)
Red Hoses
Removed Tach
Removed Speedometer
hillbilly is offline
post #3 of 27 (permalink) Old 05-08-2010, 12:08 AM
dirtrack650's Avatar
If SeaFoam doesn't clean out the carbs, ChemTool B12 is stronger/harsher detergent. Don't leave it in more than 20 minutes.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 27 (permalink) Old 05-08-2010, 01:27 AM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Check All your Hoses. Mine had Leaf Rollers in them and shut the gas flow to My Carbs. (Plus other things that were missing off the Carbs)
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #5 of 27 (permalink) Old 05-08-2010, 05:21 PM
Have you cleaned the carbs?? Your are not getting constant fuel flow. No fuel it won't run. Too much fuel it won't run.
post #6 of 27 (permalink) Old 05-09-2010, 09:24 AM Thread Starter
Well
I was 10 seconds away from calling everyone on the forum a liar who said the carbs actually come out from between those heads!! Holy crap was that a pain in the butt!
Opened up the bottom cap on the bowls and they had some hard gas goop in there; those two pieces that screw out were fairly gummed up also. What are they called? I am a pretty good "back yard" mechanic but this is the first bike I've ever really messed with so I'm counting on luck and patience, neither of which I have an abundance of!
The starter is also complete crap; after I took it apart and cleaned it up it worked better for one or two try's but now it's crap again.
Who is the best (or even good) to order parts from? Any favorites? The local stealership I think has a 300% mark up.
________
SCV100
post #7 of 27 (permalink) Old 05-09-2010, 10:46 AM
eBay for a strater rebuild kit, lance for carb parts
post #8 of 27 (permalink) Old 05-09-2010, 09:28 PM Thread Starter
Ok, I got the carbs back in (miracle) and she started right up. Idles ok with the choke on but dies if I turn it off and doesn't throttle up well either. Not going to worry about it right now; I just wanted to make sure the engine was good before I started spending money on the rest of the bike. The spline lube is next. I am really getting excited about my $1 bike!
________
Yamaha YZ250
post #9 of 27 (permalink) Old 05-09-2010, 10:59 PM
jmcclure's Avatar
Still not running with the choke off? Sounds to me like the jets are still clogged. Keep cleaning. Good luck / btw - still an awesome deal you got! Even if the motor was shot, you could have made a decent profit on parting it out alone! Keep the shiny side up....
95' 750vn
10,900 - Bought
Custom Straight Pipes
Jet kit / carbs re-built
Final Drive Serviced
New Plugs
Maintenance Free Battery
VN900 Seat
Turn Signal Relocation
Still have lots of stuff to do, just need the green to proceed! Oh, and momma's approval....
jmcclure is offline
post #10 of 27 (permalink) Old 05-12-2010, 08:11 PM Thread Starter
Still dirty?? Damn it! Messing with it today; still dies when I take the choke off. Runs like crap. Also will NOT throttle up past 5000rpm. it just stops there and starts cutting out. I am a little worried about some noise though; when its idling (it idles really low and adjustment won't turn either way) it sounds like a clunking in the engine. scaring me!
________
Honda RC112
