cotter pins for carb levers... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-06-2010, 03:51 PM Thread Starter
CANNiBAL_EyEZ's Avatar
anyone know what size and where to get these? I went to auto zone and they said they don't have any that small!!! I'm putting my carbs back together this weekend and need something to put in here. When I took them apart, I didn't pull out cotter pins, it looked like someone used paper clips that were cut and bent to hold the levers together.
THEY CALL USE WALKING CORPSES
UNHOLY LIVING DEAD
CANNiBAL_EyEZ is offline
post #2 of 8 (permalink) Old 05-06-2010, 04:15 PM
MANIC MECHANIC
vulcanjoe's Avatar
i use paper clips no problems here
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 8 (permalink) Old 05-06-2010, 06:16 PM
I used lacing wire on mine... its a little lighter strength than the paper clips.. but stronger than the stock cotter pin i removed. NAPA or any hardware store should have the correct cotter pins...as for size, I am unsure.
post #4 of 8 (permalink) Old 05-06-2010, 07:45 PM
Crobins365's Avatar
Try Home Depot or Lowe's. They have various small sizes. You need something tiny enough to fit through the hole, which is not the strongest small size available. However, if you wrap it around sufficiently, you should be ok.
C
Crobins365 is offline
post #5 of 8 (permalink) Old 05-06-2010, 11:05 PM
MANIC MECHANIC
vulcanjoe's Avatar
it doesent have to be strong it just has to keep the levers from slipping off
34k so far
coastered
spline lube
TPE stator
post #6 of 8 (permalink) Old 05-18-2010, 07:54 PM
ruk
I too used the larger size paper clip. I just cut it to size and wrap it around the head.works just the same. the larger size paper clip fits perfectly thru the hole. just my 2c.
Ruk,
2001 VN750-Black/Silver
9900 Miles
Stock Everything
=Rotella-T 10W-40, SuperTech 6607=
ruk is offline
post #7 of 8 (permalink) Old 05-18-2010, 11:19 PM
GuyP's Avatar
McMaster.com Item #98401A910 http://www.mcmaster.com/#98401a910/=76fmzi They are a whopping $2.25 per 100 in stainless. I have like an extra 98 pieces extra.
Edit; Corrected the link
GuyP is offline
post #8 of 8 (permalink) Old 11-02-2018, 12:27 PM
Location: southern, western, middle Tennessee backwoods
I use stainless steel .030 mig wire shaped to an 'S'.
"I need yo clothes, yo boots and yo motocycle."- Uncle Bob
roadpouring is online now
