Carb Out, Now How To Clean/Rebuild - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 05-04-2010, 04:34 PM Thread Starter
I was able to remove the carbureator this afternoon in order to attempt to clean/rebuild them. This is my first bike and I have NO experience whatsoever. Can someone get me a link or instructions on what I need to do? I saw that a carb rebuild can run $300, but would it run that high if I have already taken them off of the bike?
Also, since it was removed I was able to look down into the head and there seems to be quite a bit more gas sitting in there than there should be, is this because of the carb?
Thanks All, Rock on!
manofsteelfandm is offline
post #2 of 13 (permalink) Old 05-04-2010, 07:25 PM
do you have the Kawa Service manual? it gives real in depth carb rebuild procedures. I have done a lot of carb work over the years, and I was very intimidated by the nv750 carbs...until i took apart the first one and saw how simple they are.
post #3 of 13 (permalink) Old 05-04-2010, 09:30 PM
Free manual: http://www.tocmanufacturing.com/File...nd%20Parts.pdf
Start on page 17 for the carbs.
https://www.vn750.com/forum/11-vn750-general-discussion/9127-top-ten-items-you-would.html
post #4 of 13 (permalink) Old 05-05-2010, 09:31 PM
I feel your pain,I took out my carbs this evening, and they're sitting on the kitchen table. Good thing I already have the manual OlHoss posted, I say good luck to both of us.
cdaddy is offline
post #5 of 13 (permalink) Old 05-05-2010, 11:20 PM
MANIC MECHANIC
vulcanjoe's Avatar
i wish i had known about the online manual before i bought the paper manual
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #6 of 13 (permalink) Old 05-05-2010, 11:21 PM
Chucklehead
dragon159's Avatar
Take your time and all will come out well. The first time takes the longest. I can now have them out, pulled apart, cleaned, and back in in about 2 hours. Gotta stop using cheap gas.......
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #7 of 13 (permalink) Old 05-06-2010, 07:17 PM
I have both, and I use both of them just as much... the paper one is more convenient for using in the "Man Cave"
post #8 of 13 (permalink) Old 02-09-2012, 02:13 PM
Quien me puede ayudar? pues tengo una Kawsaki Vulcan 2001 y de ves en cuando se me apaga, que pudiera ser el problema
Who can help me? I have a Vulcan Kawsaki 2001 and once in a while I was off, that could be the problem
jorgetaxe is offline
post #9 of 13 (permalink) Old 02-09-2012, 02:14 PM
Question
post #10 of 13 (permalink) Old 02-09-2012, 02:43 PM
Yes, they ride much better with you ON them.
Tags
carb , clean , gas , rebuild
