Idle unbalanced - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-10-2010, 09:50 AM Thread Starter
Idle unbalanced
I bought a 1986 vn750 last year. Marbled, degoated, debaffled, Iridium spark plugs, 30,000 miles. Compression test excellent. The front cylinder has always idled lower than the rear, about 300 rpm difference. It sort of gargles at idle on the front cylinder. About two months ago I fired it up and the rear cylinder would not idle but now the front cylinder idled perfect. Pulled the carbs and cleaned and found rear cylinder idle jet clogged. After reinstalling, the rear cylinder idled fine but the front cylinder went back to low exhaust pressure compared to rear at idle and about 300-400 rpms lower on front cylinder. I am down to the conclusion that my carbs are out of sync? The bike runs perfect but just has the idle issue. Also, it is set at 900 rpms at idle. If I raise the idle to 1200 rpms the front cylinder seem to come to life more but you can tell that is is still lagging behind the rear cylinder by (Guessing) about 300-400 rpms. Will to much vacuum cause this? Its the only thing left that I can figure.....carb sync.
cruiser86 is offline
post #2 of 4 (permalink) Old 04-10-2010, 10:04 AM Thread Starter
idle unbalanced
Also, more detailed. I put on all new fuel lines and vent hoses. I have tested/sprayed all carb boots for leaks. I have check petcock for leaking into vent hose. All good so I am back to carb sync has to be the problem? I can't think of anything else it could be. Going to sync carbs today.
post #3 of 4 (permalink) Old 04-10-2010, 04:25 PM
The Professor
lance328's Avatar
Syncronize the carbs.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 4 (permalink) Old 04-10-2010, 08:12 PM Thread Starter
Smile
yep...thanks. Syncing the carbs did the trick.
