What did i do?!!!??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 03-25-2010, 10:21 AM Thread Starter
cwalley's Avatar
Send a message via Yahoo to cwalley
I may have cuased a problem with my carbs i started tinkering with the idle air knob and then my bike started running like crap then quit alltogether and now the knob is so far out of wack it wont start is there a starting point for the idle air knob or am i mechanic bound?
cwalley is offline
post #2 of 8 (permalink) Old 03-25-2010, 12:09 PM
Are you talking about the idle speed knob on the left side of the bike, or the actual idle air/fuel mixture screws? Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #3 of 8 (permalink) Old 03-25-2010, 12:20 PM
On His Lady Vulcan
wkrizan's Avatar
Or the sync screw?
Pictures of the "Ladies"
wkrizan is offline
post #4 of 8 (permalink) Old 03-25-2010, 12:54 PM
skalding's Avatar
I'd suspect you made it either way too rich or lean - if you're talking about the plastic knob on the left side. Why were you monkeying around with it anyway?
If you can get the bike started, you might try holding the throttle and reving it up around 2-3k rpms. Once the bike is somewhat warm just start turning the knob and letting off the throttle to see where it's idling. (Make sure your choke is off for this part.)
If the bike dies, you can turn the knob to increase the idle speed. Start it up, let go of the throttle, and see where the idle is.
Or if the bike continues to idle above 1K, (i.e., when you let go of the throttle, the bike continues to idle 2-3k rpms), just screw the knob back down to an acceptable 1k idle. . .
The online manual can tell you how to turn the knob to increase or decrease idle. I can't remember it offhand.
Of course if you messed with the small brass air idle screws on the sides of the carbs, you can just screw them all the way in, then out 2.5-3 turns as a starting point.
If you messed with the bolt head/screw slot thing that sits at the very bottom between the carbs, do a search for "balancing carbs" and for how to make yourself a $5 carb balancing tool out of clear vinyl tubing, excess oil, and a stick.
Let us know what's up.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #5 of 8 (permalink) Old 03-25-2010, 05:07 PM
Quiet rider
greyhound's Avatar
Isn't the plastic knob adjuster only an adjustable mechanical stop of the throttle linkage? i.e., doesn't effect rich / lean but position of throttle at idle?
Greyhound
01 VN750
36k miles
No one on their deathbed ever said "I wish I had spent more time at work".
greyhound is offline
post #6 of 8 (permalink) Old 03-26-2010, 01:17 PM
skalding's Avatar
Yep - you're right. Brain cramp on my part.
Same walkthough to adjust the idle speed though.
Scheherazade
'86 VN750
skalding is offline
post #7 of 8 (permalink) Old 03-29-2010, 01:58 PM Thread Starter
cwalley's Avatar
I do'nt know why i monkey around with these things i just cant help my self anything i buy i have to tinker withit until i break it and have no choice to fix it or just completly rebuild it for no reason at all. still just a little boy at heart i guess
cwalley is offline
post #8 of 8 (permalink) Old 03-29-2010, 01:59 PM Thread Starter
cwalley's Avatar
i got her running and running better than ever it was just the idle air on the left side of the bike i also removed all my cali emission control crap and she is runnin like a scalded dog now thanx for all the advice
cwalley is offline
