hard to start after ear shave - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 03-21-2010, 08:22 PM Thread Starter
jebusbud's Avatar
Send a message via Yahoo to jebusbud
Angry hard to start after ear shave
Been working on a bobber build over the winter. did the ear shave, new MF battery, new plugwires with new NGK caps, 142 main and 42 pilot jets. Bike takes forever to start most times completely draining the battery and having to jump it off. once started, it runs great till i kill it again, plenty of power, no smoke out the exhaust. doesn't matter if hot or cold start. any help would be great. getting too nice out to have the scoot down any longer!!
Mods so far:
6" wide flat fender
Hardtail struts
Side mount license plate w/ Model A Ford tail light
KZ650 Headlight
Sprung solo seat
Relocated speedo
Relocated electronics
T/S removed
Tach removed
Dash removed
Suicide shift
Jardine exhaust
Relocated highbeam and oil indicators
Relocated ignition, horn, and highbeam switches
Coming Soon:
Chain sissybar
Chain shifter
jebusbud is offline
post #2 of 16 (permalink) Old 03-21-2010, 09:02 PM
I had the same problem and the starter was dragging and pulling so many amps I had very weak spark at the plugs Iridium plugs helped but the starter was my problem,although you should check for loose or corroded connections first.JMO
post #3 of 16 (permalink) Old 03-21-2010, 09:17 PM
The Professor
lance328's Avatar
Make sure the battery is fully charged and install NGK DPR7EIX-9 spark plugs. Set the pilot screws @ 2-1/2 turns out and you can adjust from there. Set the choke about half way, you may need to adjust the pick-up coils to advance the ignition timing.
Did you put 2 shims under each needle?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 16 (permalink) Old 03-21-2010, 10:21 PM
dirtrack650's Avatar
I'm in the same situation. Did the AGM batt and iridium plugs. Worked sweet for a year, now back to hard start and backfire. I suspect the starter is pulling too many amps away from the the system to function properly. If I push start, it bumps right over and fires right up.
This time, the starters going in for a rebuild at a local auto electric shop that I trust. I'll let you all know what the outcome is. While the starter's out, I'll adjust the pickup gap.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 16 (permalink) Old 03-22-2010, 02:40 AM
The Professor
lance328's Avatar
DT
A half dead starter will suck the life out of the best battery.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 16 (permalink) Old 03-22-2010, 10:36 AM Thread Starter
jebusbud's Avatar
2 shims under each needle, battery fully charged. don't have the iridium plugs yet cause i don't want to foul high dollar plugs trying to get this thing to run.
Mods so far:
6" wide flat fender
Hardtail struts
KZ650 Headlight
Sprung solo seat
Relocated speedo
T/S removed
Tach removed
Dash removed
Suicide shift
Jardine exhaust
Coming Soon:
Chain sissybar
Chain shifter
jebusbud is offline
post #7 of 16 (permalink) Old 03-22-2010, 03:18 PM
fergy's Avatar
So are you saying you are fouling the existing plugs now? Or was that just a "what if" statement? Have you checked your plugs while you are trying to start the bike? Are they wet?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #8 of 16 (permalink) Old 03-22-2010, 03:21 PM Thread Starter
jebusbud's Avatar
think i just need to adjust the carbs some more. starting to do a little better, have the pilot screws out about 3.5-4 turns, push starts just fine, maybe time to replace the starter...
Mods so far:
6" wide flat fender
Hardtail struts
KZ650 Headlight
Sprung solo seat
Relocated speedo
T/S removed
Tach removed
Dash removed
Suicide shift
Jardine exhaust
Coming Soon:
Chain sissybar
Chain shifter
jebusbud is offline
post #9 of 16 (permalink) Old 03-22-2010, 03:22 PM Thread Starter
jebusbud's Avatar
got a little wet from all the cranking without firing off. want to get it dialed in some more before i get the good plugs
Mods so far:
6" wide flat fender
Hardtail struts
KZ650 Headlight
Sprung solo seat
Relocated speedo
T/S removed
Tach removed
Dash removed
Suicide shift
Jardine exhaust
Coming Soon:
Chain sissybar
Chain shifter
jebusbud is offline
post #10 of 16 (permalink) Old 03-22-2010, 08:13 PM
Here is a starter on ebay.
http://cgi.ebay.com/ebaymotors/1996-...Q5fAccessories
