Won't go above idle and dies with out choke - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 03-11-2010, 12:50 PM Thread Starter
Ryan's Avatar
I just got the bike and I could only get it to run with the choke on and if I touched the choke lever or the gas it would die. I took off the tank to remove the old gas thinking that it might have been the problem and found the vacuum line to the petcock had a hole in it, I replaced that. I put the tank back on and put some gas in it and same thing. I took the tank back off and started cleaning the carbs and found both of the diaphragms were stuck. I go those unstuck and I was running the bike without the gas tank on it, I had the petcock vacuum line plugged, and all the rubber connections to the air boxes are removed and it would still only idle and if I touched the gas it would die. I am pouring gas into the fuel lines to test it. I am wondering if the air box connections being off have anything to do with the problem or should I keep cleaning the carbs. As a side note I know who ever had the bike before me did remove the carbs before and might have messed something up, the guy did not seem to bright.
94' Vulcan 750
Ryan is offline
post #2 of 3 (permalink) Old 03-11-2010, 07:28 PM
The Professor
lance328's Avatar
Did you remove the jet covers and clean the jets?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 3 (permalink) Old 03-11-2010, 08:09 PM Thread Starter
Ryan's Avatar
Yes, I just spent the last 3 to 4 hours pulling the carbs off and cleaning them. I put them back on. I got it running right now.
94' Vulcan 750
Ryan is offline
