Lucas Fuel Treatment - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-06-2010, 02:46 AM Thread Starter
stiervulcan's Avatar
I purchased some Lucas fuel treatment for use in my truck at the recommendation of a co-worker. I have just added it so I don't have any numbers yet. But has anyone here used it on a bike, or at all for that matter.
The bike will start but it starts hard and I think I am going to wait till I can drain the tank and carbs to make sure I am not just making a problem worse. The PO said he had not ridden it in over a year but it had a new battery and tires before he decided to sell it, he did not keep it on a tender neither am I at the moment. The Lucas fuel treatment is supposed to be an "upper cylinder lubricant" and it is a thicker liquid, is seafoam like that? From reading I had assumed it was thinner, but we know what we get when we assume.
K&N filters
MF-AGM Battery
93' VN750 / 13,600mi
Vestal, New York
stiervulcan is offline
post #2 of 5 (permalink) Old 03-06-2010, 03:02 AM
I have used it in my car, never in a bike...good stuff, but after coming here and being turned onto seafoam, I haven't run anything else since
post #3 of 5 (permalink) Old 03-06-2010, 07:57 AM
cm4cm5's Avatar
ive had my bike for 5 years now, i know with out seafoam i would have pulled carbs a couple times for cleaning, but i use it religously, every other tank ill put in 4 or 5 oz. (can says 1oz for 1 gal, but whows mesuring ) when im ready to ride, just a tap on the start butten, shes fires up and ready to run. i can run all day with out a hick up, i have not ever pulled the carbs off for cleaning, i see no reason to.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #4 of 5 (permalink) Old 03-06-2010, 04:24 PM
Lucas makes good stuff, I use all Lucas lubricants in my race car, but I would stick with Seafoam for bikes. It has been proven to work, and is also known to be safe. Some car products will damage bikes, especially fuel system cleaners. For example, if you put Gumout in your gas, you will likely be removing your carbs to replace every plastic and rubber part that comes in contact with fuel. Yet it is fine for cars. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 5 (permalink) Old 03-07-2010, 03:10 AM Thread Starter
Thanks guys... I will invest in the seafoam.
K&N filters
MF-AGM Battery
Vestal, New York
