Losing power at speed, eventually stalling - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 49 (permalink) Old 02-25-2010, 01:39 PM Thread Starter
This has happened a couple of times, now:
Riding along happy as a clam (first time at 55mph, the second at 70), when it starts hesitating and eventually there's no power at all. Pulling over, the bike eventually dies and will not start.
After 10 minutes or so, it starts up just fine.
It appears to be a carburetor issue. It's an old bike ('85 VN700) and could prolly do with a full blown carb work-over and clean. I've seen a few threads about problems similar to this. I'm running a bit of seafoam in the tank - maybe a quarter bottle per tank.
However, here's the thing I don't understand. When it dies, the gear change lever just won't do anything: It doesn't appear to change gear back to 1st (or go up in gears either, which I'd expect), and it won't hit neutral. After sitting for 5 minutes, I can put it in neutral - that is, the neutral light comes on. It won't start at this point; a few more minutes later and it'll start.
So, I'm sure there's a couple of carb things I can work on, but why the 'gear change' issue (not being able to put it in neutral)? Is there a 'link' I'm not thinking of?
Last edited by OceanTwo; 02-25-2010 at 01:40 PM. Reason: title was a bit misleading
OceanTwo is offline
post #2 of 49 (permalink) Old 02-25-2010, 02:13 PM
flitecontrol's Avatar
Sounds like possibly more than one issue. The bike dying sounds like the "phantom out of gas syndrome", which I believe is related to insufficient venting of the fuel tank. If you open the tank cap and can start it back up again immediately, it's probably vent related. Clean the vent hole, which is near the cap hinge, with a pipe cleaner.
Not sure what is going on with the shift issue and how it may be related to the hesitation/dying.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 49 (permalink) Old 02-25-2010, 03:53 PM
Chavisimo's Avatar
When it dies again, try pulling in the clutch and move the bike forward while trying to shift.
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
post #4 of 49 (permalink) Old 02-25-2010, 10:57 PM
I don`t recall anyone using a pipecleaner ,fc. I haven`t looked into mine yet, but I think the recommended method is to remove the gas cap and use a TINY TWIST DRILL BIT, to ever so slightly enlarge the vent hole.
EDIT: Try cleaning the vent by spraying some aerosol wd-40 through at the gas cap, and watch for it to drip from rubber hose down near the rear tire. Compessed air could also be tried.
I`m sure someone who has performed this little operation will chime in with the particulars.
To confirm the "Phantom out of Gas Syndrome", put an extra key in the gas cap (or not, `85 model may not have key lock in gas cap). When the engine starts to die, open gas cap to relieve vacumn in tank. If the engine regains power, you have identified the problem. The better part is, the fix is quick, easy and no/or low cost.
post #5 of 49 (permalink) Old 02-26-2010, 08:28 AM Thread Starter
I tried opening the gas cap, just after it stalled, the second time. Unfortunately, it didn't allow the bike to start. It may be that the bowls were not full enough yet (it was about 8 or 9 minutes before it would start).
[The gear change thing: I now recall when doing the spline lube and gear change pawl spring replacement, having the front bevel gear casing off that the gearbox/splines needed to be in a certain position for it to actually change gears - so, I think a red herring, here].
I'll try the vent tube clean, but the gasket on the tank doesn't appear to hold a very good seal, anyway, so am not convinced this will solve the issue. It's a cheap fix if it does, though.
OceanTwo is offline
post #6 of 49 (permalink) Old 02-26-2010, 09:44 AM
hmm, i've had that problem too. in the case my engine wont start on me i cannot shift out of 1st or Neutral. so i cant seem to do a proper rolling start.
do a carb clean out. i bet your jets are clogged.
6204 is offline
post #7 of 49 (permalink) Old 02-26-2010, 10:12 AM
Could have sworn I read that tip here, but I've been wrong before!
"Black Beauty"
Old Blue
post #8 of 49 (permalink) Old 02-26-2010, 11:14 AM
I have heard it too... some one last summer posted the pipe cleaner trick to get dirt and debris out of the hole...the problem isn't that the hole is too small, but rather he hole getting clogged
post #9 of 49 (permalink) Old 02-26-2010, 05:33 PM
Check the vaccuum hose to the carb from the petcock for cracks that can cause it to leak air into it.
post #10 of 49 (permalink) Old 03-02-2010, 02:19 PM
TechMech's Avatar
Chiming in on the vaccuum hose from the carb to the petcock: I'm convinced that if the hose is old it gets hard and doesn't make a leak-free connection even if it doesn't have cracks. After many tries, replacing the hose with a new one is the one thing that appears to have fixed my "phantom out-of-gas syndrome" problem.
TechMech is offline
