hot and cold start problems. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 02-18-2010, 02:51 AM Thread Starter
juggalo62989's Avatar
Question hot and cold start problems.
hi.
the only way i can get my 2004 vulcan to start. both when its cold and when its hot, is to turn the idle screw way down.
ive put new plugs in and ive relocated the R/R. i do have drag pipes now but it was doing this when i had the stock exhaust too. im going to try seafoam tomorrow. ive read it works miracles on our bikes. but does anybody have any other ideas?
windshield.
red leds.
straight pipes.
vroc number 25695
juggalo62989 is offline
post #2 of 16 (permalink) Old 02-18-2010, 09:50 AM
cglennon's Avatar
Have you replaced the battery with an AGM maintenance free version yet? This solved my warm start issues on a 2006 model (didn't have a cold start issue).
Chris Glennon - Portland, OR
cglennon is offline
post #3 of 16 (permalink) Old 02-18-2010, 11:22 AM
flitecontrol's Avatar
And if your new plugs aren't iridiums, they do give a very good spark. When I bought my bike, it had standard plugs with only 350 miles on them. Replaced the battery with AGM and put in iridium plugs. Man, what a difference!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 16 (permalink) Old 02-18-2010, 01:01 PM
Calif Rider
weh44att's Avatar
Juggel you can also try the ignition coil pickup adjustments, they are located in the stater area. You just have to pull off the stater outer cover, only three screws. There is a write up in the forum threads covering the whole procees. The pickups come set with a gap of some where between 30 to 40 thousands of an inch. You need to get them down to about 18 to 20 thousands of an inch. This should take care of all the cold and hot starts, along with the plugs and AMG battery.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #5 of 16 (permalink) Old 02-18-2010, 01:58 PM
__________________
Be mindful, that this mod is not a simple adjustment, and is not completely irreversible.
post #6 of 16 (permalink) Old 02-18-2010, 04:14 PM
Originally Posted by juggalo62989 View Post
hi.
Are you using the choke to start the bike when it is cold?
Does it seem to run fine once you start it (guessing you turn the idle back up then?)
post #7 of 16 (permalink) Old 02-18-2010, 06:23 PM
The Professor
lance328's Avatar
The mod takes about 30 minutes and is completely reversable. I have done this on 8 engines and no one has asked to change it.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 16 (permalink) Old 02-18-2010, 08:06 PM Thread Starter
what i have to do is wait for it to fire without choke then kind of juggle the gas and choke til it stays running...
also if i do turn the choke on while its turning over it seems to crank slower. it does the same thing if i give it gas.
im thinking something electrical as well.
windshield.
red leds.
straight pipes.
vroc number 25695
post #9 of 16 (permalink) Old 02-19-2010, 01:21 PM
The Vulcan 750 is known for starting problems. Owners have done all kinds of things to try and solve the issue. I have not messed with the ignition coil pickup adjustment, but I did install an AGM battery, gapped the plugs just a hair less than what the manual calls for, removed and thoroughly cleaned the inside of the starter, and have turned the pilot screws out a full 3 turns. If started every day or two, it starts fine. If you let it set for a week, it can be hard to start. I believe this is caused by gas evaporating out of the float bowls.
Seafoam is good stuff, but costs about the same as it's weight in gold. For that reason I don't use very much of it. What I do, is about every 3 months, drain the gas out of the carbs, disconnect the fuel lines from the petcock, and fill the float bowls full of Seafoam through the fuel lines, let it soak for 24 hours, then drain it out. I use the remainder of the 16 oz can in the next 2 tankfuls of gas. I have 4 other bikes, and don't use Seafoam in any of them, I only use it in the Vulcan because it is such a PITA to remove and clean the carbs.
Are you a member of the ICP? Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is online now
post #10 of 16 (permalink) Old 02-19-2010, 07:52 PM
slim, I think you meant to say the mod is not reversible, or that it is irreversible, which means the same thing. By trying to emphasize irreversible with "not", you have a double negative (ir and not, which equals a positive), which means exactly what lance says- "completely reversible".
Tags
cold , problem , start
