Draining Carb - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 02-17-2010, 12:18 PM Thread Starter
Draining Carb
Hello, Would like to drain the carb before the start of the season (NJ). Where are the drain plugs located? Are there 2 on the bottom of each carb? Have a 2003. Any pics would be a huge help. Glad to be on the site! Thanks in advance.
mickey993 is offline
post #2 of 4 (permalink) Old 02-17-2010, 06:49 PM
Calif Rider
weh44att's Avatar
Sorry no pictures but the drains or on the very bottom of the carbs. They are the allen set screws just above the tip that is at the bottom of the carb. Put a plastic tube on the tip and have the fuel drain into a glass jar, so you can see what has come out of the drain.
To refill the cabs,disconnect the vac line from the petcock and apply suction. This opens the petcock valve to refill the carbs.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 4 (permalink) Old 02-17-2010, 08:44 PM
Here are pics of the carbs with names of all the parts... it should be helpful to you.
post #4 of 4 (permalink) Old 02-18-2010, 08:47 AM Thread Starter
Thanks for the reply!
