Home brewed Seafoam - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 31 (permalink) Old 02-07-2010, 05:09 PM Thread Starter
flitecontrol's Avatar
Home brewed Seafoam
Guy on another forum came up with this.
"The ingredients for Seafoam are naphtha (aka white gas, coleman fuel, lighter fluid), isopropanol (aka isopropol alcohol), and pale oil (light oil). For alcohol I use the 91% stuff sold in drug stores. For oil I use Dexron ATF. Usually mix it about 1 qt Coleman fuel, 1 pint alcohol, 1/2 pint ATF. Seems to work just as good as the store bought stuff."
Be aware that most isopropanol (rubbing alcohol) in stores is about 70% alcohol and 30% water, so be sure to get the higher concentration of alcohol. I'm not having any carb problems, so don't have a good way to test this out. But think I'll try mixing up a batch when my current supply of Seafoam runs out.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #2 of 31 (permalink) Old 02-07-2010, 06:46 PM
dirtrack650's Avatar
Try denatured alcohol also from drug stores - much more pure - or how about some everclear ;-)
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 31 (permalink) Old 02-07-2010, 07:24 PM Thread Starter
Not familiar with everclear. Does it have an alcohol tax stamp?
"Black Beauty"
Old Blue
post #4 of 31 (permalink) Old 02-07-2010, 07:52 PM
everclear is the closest thing to "shine" that can be legally sold. Yes it has a tax stamp...
post #5 of 31 (permalink) Old 02-07-2010, 07:53 PM
Now what
Ironman's Avatar
Denatured alcohol has methanol in it. Might not be a good thing to run through an engine. Inhaled or swallowed it's poisonous. Everclear, being 100% ethanol would be fine. Might be expensive though and it's not available in all states.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #6 of 31 (permalink) Old 02-07-2010, 08:06 PM
I was going to mention that... Methanol is bad for the carbs...
post #7 of 31 (permalink) Old 02-07-2010, 08:43 PM Thread Starter
Well what about isoproponal? Isn't methanol what they add to gas these days? Maybe the alcohol is added to Seafoam to remove moisture in the tank.
"Black Beauty"
Old Blue
post #8 of 31 (permalink) Old 02-07-2010, 08:46 PM
THIS post from a few years ago is somewhat similar.
post #9 of 31 (permalink) Old 02-08-2010, 12:13 AM
Now what
Ironman's Avatar
They're adding ethanol to gas to cut emissions.
VROC 13864
Ironman is offline
post #10 of 31 (permalink) Old 02-08-2010, 12:23 AM
Now what
Ironman's Avatar
Even though the original quote just said Seems to work just as good as the store bought stuff. without letting us know how he determined that.(I guess the bike continued to run after he added it to the gas tank). You could run a little test to compare the home brew with the Seafoam. Put a pea-size amount of tar (or something tar-like) into two jars and add Seafoam to one and the home brew to the other. Let them stand overnight (don't shake) and see if the tar has dissolved the same in each jar (or about the same).
VROC 13864
Ironman is offline
