Stuck gas cap! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 11-20-2009, 07:55 PM Thread Starter
Stuck gas cap!
hHey guys how is everyone doing on this fine Friday.
HOw ca I open the gas cap on my vn that is stuck broke 2 keys already?
dre82s is offline
post #2 of 6 (permalink) Old 11-20-2009, 08:04 PM
Simple Solutions
seebeeare's Avatar
sounds like the lock is jammed pb blaster might loosen the tumblers other wise u may need a lock pick kit and something strong to turn the lock ... a lock smith would probably be your best bet ... u sure u have the right key???
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 6 (permalink) Old 11-20-2009, 08:43 PM
Love My Baby
rubyrick's Avatar
Is there a key stuck in the gas cap lock now? Or is the lock just stuck and the broken key removed?
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 6 (permalink) Old 11-20-2009, 09:27 PM
There is a roll pin in the back of the gas cap that can be driven out with a drill bit.
You can then pull the cap up and back to get it out of the tank
1992 Vulcan 750
Bought May 2008 Mileage 12,499
Current Mileage 20,600
R/R Replaced/Relocated
delenew is offline
post #5 of 6 (permalink) Old 11-20-2009, 09:46 PM
flitecontrol's Avatar
I just bought some DuPont Teflon Multi-Use Dry Wax Lubricant at Lowes. It loosened up two frozen locks on my camper shell and made a couple of sticky padlocks smooth as silk. Might do the trick on your cap. About $5/can. Bought it to lube the chain on my other bike, but I'm finding lots of uses.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #6 of 6 (permalink) Old 12-14-2009, 01:54 PM Thread Starter
I douged it with WD-40 and it finelly broke loose, I took the mechanism apart and ther was a white build up in the mechanism where the toungue slides in and out!
dre82s is offline
