grip stuck when i release throttle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 11-14-2009, 06:10 PM Thread Starter
justjim910's Avatar
i just put my carbs back on after cleaning them ( and everyone was right leave the boots on the head on) so after 1& 1/2 hrs and 4 beers i got it back in good to go. so after its in i realize i didnt connect the throttle cables back up now 3 beers later i got them back on but when i pull the throttle back like im giving it gas it just stays there and i get no snap back from my throttle grip so i took that apart it looked fine the wires where moving as they should but the "push" wire seemded to have a little slack in it any help or sugestions ?
thanx
jim
her name is lucille and she's all mine
justjim910 is offline
post #2 of 12 (permalink) Old 11-22-2009, 08:22 PM
Mine does the same thing. I just look at it as cruise control. I know that is slack but oh well.
Vulcan man is offline
post #3 of 12 (permalink) Old 11-22-2009, 09:02 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
Try adjusting the throttle cables. When were the cables lubricated last?
cliffhusn is offline
post #4 of 12 (permalink) Old 11-23-2009, 08:07 AM
Are you sure the cables are routed the exact same way as before you worked on the carbs?
post #5 of 12 (permalink) Old 11-23-2009, 08:20 AM
Love My Baby
rubyrick's Avatar
Originally Posted by justjim910 View Post
...so after 1& 1/2 hrs and 4 beers i got it back in good to go. so after its in i realize i didnt connect the throttle cables back up now 3 beers later i got them back on but...
I suggest you work on your bike BEFORE you consume 7 beers!
Works for me.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #6 of 12 (permalink) Old 11-23-2009, 11:56 AM
letitflight's Avatar
Works for me.
It's better with the beers though more challenging
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #7 of 12 (permalink) Old 11-23-2009, 12:40 PM
flitecontrol's Avatar
And often leads to other things that need fixing!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #8 of 12 (permalink) Old 11-23-2009, 01:07 PM
At Least I Can Spell!
msh1156's Avatar
If had a drunk 7 beers, I'd be we023i ssdjh29w**)WEsdhf336w$%^&jsdh
hic! burp!
puke.
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #9 of 12 (permalink) Old 11-23-2009, 02:35 PM
True that Flitecontrol
here is my two cents, grease the throttle cable. open and clean the housing assy control, add some grease on the throttle cable (within the housing)- enough to reduce friction between plastic.
good luck!
PEACE!!!
2005 Vulcan 750
post #10 of 12 (permalink) Old 11-24-2009, 12:43 PM
Now that sounds about right. Ask me how I know! LoL.
Misfittom138 is offline
