Bike cuts out?????? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 11-05-2009, 08:01 PM Thread Starter
Bike cuts out??????
i am looking at a 1991 vulcan 750 that is mint. only has 4,500 miles. when test driving it ran perfect, started up excellent and ran great but when you hit around 5k rpm the bike kind of cuts out a little. it feels almost like a rev limited kicked in, i know the bike dont have one but thats what it feels like. i didn't notice if the bike pulled through after giving the gas for a while because i just let off right away. what could it be?? you can also email me at [email protected]
post #2 of 8 (permalink) Old 11-06-2009, 08:34 AM
sounds like there is sentiment in the fuel bowls on the carbs, or their could be a vacuum leak at the carb boots, also could be the petcock not working right... if this is a problem that you are worried about costing a lot of time and money to fix... i doubt it... i would buy the bike, ten come back here and we can walk you through the sets and fixing.
post #3 of 8 (permalink) Old 11-06-2009, 09:07 AM
GIMPYRDR's Avatar
X2 what Slim said. There is more than enough experience and info here.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #4 of 8 (permalink) Old 11-06-2009, 01:50 PM
Calif Rider
weh44att's Avatar
It also could be the vent line that goes to the right air filter. The end of the tube should be cut slanted so it will breath properly if pushed in to far. If the air is restricted it will affect the high RPM's
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #5 of 8 (permalink) Old 11-06-2009, 02:25 PM
Welcome to the Vulcan madness countryboy. X3 to slims suggestion.
BTW slim, do you mean "sediment"? lol. I think you are typing under the infuence of too little sleep, and no spell checker.
post #6 of 8 (permalink) Old 08-16-2014, 06:36 PM
Dragon Master
yeah I know this is old.
Just out of curiosity What was the cause of the issue? I have a similar issue going on right now.
ddesorbo is offline
post #7 of 8 (permalink) Old 08-16-2014, 07:04 PM
2000 VN 750 Senior Member
You are tied into a thread from 2009. There is only one member from that thread that I recognize as being still active.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #8 of 8 (permalink) Old 08-16-2014, 07:06 PM
The outcome was he didn't buy the bike.... Post your own thread and we will help fix you up
