Using the Choke - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 11-01-2009, 05:34 PM Thread Starter
Columbus, Ohio
jimkonst's Avatar
Using the Choke
At times I have been motoring down the road and discovered that my choke is still half or slightly on. My question is, does the choke work for the full travel of the thumb handle, or just the first bit of it? Am I wasting gas when this happens or does it matter?
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #2 of 5 (permalink) Old 11-01-2009, 06:39 PM
Now what
Ironman's Avatar
If it's adjusted properly, it works over the whole distance. It's actually an enricher so, yes, you would be wasting gas. The bike will be running too rich and that will lead to fouled plugs. If the bike won't run properly after it's warmed up without some choke, there's trouble in the carburetor.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #3 of 5 (permalink) Old 11-01-2009, 07:19 PM Thread Starter
Columbus, Ohio
jimkonst's Avatar
Thanks. The trouble is the addle-pated operator. I take off with half choke 'cause it feels like it needs it, then forget to open it on down the road.
Jim
Sold my Vulcan
jimkonst is offline
post #4 of 5 (permalink) Old 11-01-2009, 10:07 PM
Love My Baby
rubyrick's Avatar
On occasion I do the same thing. But when I idle or take off from a light, the engine is just so darn responsive that it jars my memory to take the choke off.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 5 (permalink) Old 11-02-2009, 09:58 AM
Been there, done that.
I usually notice it when, after the first couple miles, the bike doesn't seem to be running right. Then it hits me..... uh, check the choke dummy!!... yep it's still partially on
