Sputtering and dieing under 4000 rpm - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 11-01-2009, 03:23 PM Thread Starter
It will run fine for a few minutes but once it is warmed up it will start to sputter and back fire really bad. Then if I let it drop below 4000 rpm it will just die. It will start right back up but again die if it drops. I used premium fuel from a reliable seller.
br0k3nskyy is offline
post #2 of 14 (permalink) Old 11-01-2009, 04:00 PM
Simple Solutions
seebeeare's Avatar
start with reg unleaded ... Trust me on this its the right choice... it burns a lot better ... used to be a premium rider myself but my ideas changed after the research...
next throw in some seafoam per instructions...
next im thinking your issue is electrical check for spark on all plugs, check ground connections and check neutral and safty switches ... how do your plugs look
im guessin u are missin on a cylinder start it up and touch the pipes see if one bank is dead....
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 14 (permalink) Old 11-01-2009, 07:57 PM Thread Starter
I did throw some gumout in it. Ill try some new gas like you said. I did check the plugs and how they were burning, none white or black, all looked like they had been burning. Just a brown color too them. Ill check for the spark as your recommended though just incase.
post #4 of 14 (permalink) Old 11-01-2009, 08:03 PM
Simple Solutions
seebeeare's Avatar
in a pinch i may try another additive but i will only recommend seafoam ... its the best stuff on earth ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #5 of 14 (permalink) Old 11-01-2009, 08:29 PM Thread Starter
Do you just add it to the gas?
post #6 of 14 (permalink) Old 11-01-2009, 09:01 PM
Simple Solutions
seebeeare's Avatar
yes but u can also add it to the oil... it has many properties that can be used ... it cleans and it stabilizes fuel it was designed originally in the marine industry
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #7 of 14 (permalink) Old 11-01-2009, 09:23 PM
flitecontrol's Avatar
To my knowledge, there is no substitute for Seafoam. Lots of look-alikes, but no substitute.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #8 of 14 (permalink) Old 11-02-2009, 11:32 AM
robardin's Avatar
I have a very similar sounding issue but at a lower RPM threshold, more like around 3K RPM, and I don't remember any backfiring.
The bike has a fully charged battery and starts just fine, but after about 10 minutes of riding, no longer holds an idle. If the revs drop to around 2K it starts sputtering, and at 1K it dies and then is difficult to start up again. If I keep the engine revved to 3K at stop lights and such, I can keep it from dying, but this makes it hard for me to slow down very well ahead of them because I can only use my rear brake
However, if I let the bike sit for a while I can start it up with no problems, and ride normally for another 10 minutes before it starts having the lower-rev problems again.
It's not the battery dying (weak alternator) because the bike starts fine after sitting for a while. I checked my air filters and they're fine too.
I've had dirty carbs in the past and this doesn't seem like that. When I ride at suitable speeds, the engine is smooth, not jerky or rough, plus they're fine when I first start riding, whereas when the carbs are dirty it's apparent pretty much immediately.
I refilled it with new fuel, poured an entire can of Seafoam into the tank and took it for a ride. Still had the problem.
I checked my spark plugs, which are Iridium plugs about a year old, and they look OK. Nothing black or carbonated.
Now what? Take off the fuel petcock? -- And look for what, and do what?
"Until you have the courage to lose sight of the shore, you will not know the terror of being forever lost at sea." (Despair.com)
robardin is offline
post #9 of 14 (permalink) Old 11-04-2009, 05:52 PM Thread Starter
Checked the plugs, all are firing. Battery and alternator are fine, its starts right back up. From what i have read of the carb were clogged it would die almost immediately? Where could it lose fuel pressure from after about seven to ten minutes? If the carb is blocked would it be reasonable to assume a filter wouldnt be?
post #10 of 14 (permalink) Old 11-04-2009, 07:47 PM
Sounds like a clogged pilot jet. Has the bike sat for awhile?
Seafoam always a good idea here.
Make sure all the clamps holding the carbs are tight, Check the airfilters and the air boxes for leaks.
Worst cas scenario here is you might have to pull the carbs to inspect and clean them...not a fun job on the 750.
