Gas in exhaust - running on one cylinder - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 11-01-2009, 01:33 AM Thread Starter
While I was riding on the freeway today I noticed that my bike was accelerating a little sluggishly, despite having 1/2 tank of fuel. When I got home I noticed that gas was leaking from the left exhaust where it meets the header, and the rear cylinder wasn't firing at all. The plugs were covered in unburnt fuel, even though both plugs are getting spark.
I've looked through the forum for a successful resolution to this problem, but without success. I seem to think it might be a carb problem... but what part of the carb? It seems that the rear cylinder is just being flooded with fuel, as if the needle in the main jet were stuck open.
Any thoughts?
jligman is offline
post #2 of 17 (permalink) Old 11-01-2009, 01:40 AM
Simple Solutions
seebeeare's Avatar
seafoam... seafoam....
is fuel lleaking past the float bowls???
no spark = unburnt fuel?? (check grounds connections voltage at coils and safty switched...) hust throwin things out there ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 17 (permalink) Old 11-01-2009, 01:45 AM
STUMPYSKAW's Avatar
What year, miles, mods?
let the cyl. air out and try some new plugs first, but more than likely you have a float prob. The more info you give the better we can help.
"DAISY" 85 VN 700 19K
Owned since 09/12/09
Done list
Metal radiator drain plug
Removed exhaust baffles
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
VN900 seat on my VN700
https://www.vn750.com/forum/showthread.php?t=12903
Debaffling my stock pipes
https://www.vn750.com/forum/showthread.php?t=12756
STUMPYSKAW is offline
post #4 of 17 (permalink) Old 11-01-2009, 01:51 AM Thread Starter
The plugs in the front cylinder are clean so I swapped them for the rear, which are the ones covered in gas (I cleaned them before reinstalling). I had the same problem. After running for 30second I rechecked the rear plugs and found that they were covered in unburnt fuel again.
The bike was running beautifully earlier today... and I had the carbs resynced about 2k miles ago. If it is a stuck float, is that something that I can access without pulling the carb off? It's been a long time since I've opened up a carb, so my memory is a little fuzzy....
(Also, added bike details to my signature)
'94 VN740 at 10,000 miles
r/r relocate
acct rebuild
spline lube
jafrum saddle bags
jligman is offline
post #5 of 17 (permalink) Old 11-01-2009, 01:55 AM Thread Starter
I had the same idea. Everything connected to the coil seems fine... both the wires for the front and rear cylinders have spark, it just seems that the rear cylinder is being flooded with fuel.
r/r relocate
acct rebuild
spline lube
jafrum saddle bags
jligman is offline
post #6 of 17 (permalink) Old 11-01-2009, 01:02 AM
STUMPYSKAW's Avatar
One thing to try is turning fuel off, drain rear carb( leave drain open), remove fuel line to rear carb, shoot some carb cleaner into the fuel inlet on the carb. Inspect the fuel lines for for cracks, if in doubt, replace them. if that doesn't work then I think you'll prob be pulling the carbs.
Also check to make sure the throttle slide isn't stuck open. Just pull the boot off and take a peek
Done list
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
post #7 of 17 (permalink) Old 11-01-2009, 01:14 AM Thread Starter
Thanks for the ideas. As soon as I get some sun light (tomorrow), I'll see what I can find.
r/r relocate
acct rebuild
spline lube
jafrum saddle bags
jligman is offline
post #8 of 17 (permalink) Old 11-01-2009, 01:27 AM
The Professor
lance328's Avatar
You don't need sun light, a BIC lighter works just fine. LOL
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 17 (permalink) Old 11-01-2009, 03:22 AM
Simple Solutions
seebeeare's Avatar
ROFL
bics work best for propane and natural gas leaks... (im 99 percent serious...)
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #10 of 17 (permalink) Old 11-01-2009, 05:09 AM
750Doug's Avatar
Carb float.
750Doug is offline
