help!! gas coming out of air intake - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-31-2009, 07:03 PM Thread Starter
justjim910's Avatar
Question help!! gas coming out of air intake
hi im just jim i just joined and i got a problem, i have an 89 vulcan 750. this is my first bike and i love it but dont know enough about it. the other day i took off the gas tank to see about clearance for a possable tank change. now when i start her up gas come out of the air intake ( a good amount of gas). i thought i put everything back right so i went back and swiched out the hoses to the carb to no avail i think it got worse. so i switched it back how it was. i think it might be a float or something but im a compleat novice. any good advise. thanx
justjim
justjim910 is offline
post #2 of 6 (permalink) Old 10-31-2009, 08:00 PM
The Professor
lance328's Avatar
Originally Posted by justjim910 View Post
hi im just jim i just joined and i got a problem. this is my first bike and i love it but dont know enough about it. the other day i took off the gas tank to see about clearance for a possable tank change. now when i start her up gas come out of the air intake ( a good amount of gas). i thought i put everything back right so i went back and swiched out the hoses to the carb to no avail i think it got worse. so i switched it back how it was. any good advise
justjim
You have debris in your carb float valve or a stuck float valve. You can try tapping on the side of the carbs, but you may have to remove them and clean.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 6 (permalink) Old 10-31-2009, 08:11 PM Thread Starter
justjim910's Avatar
yeah im going to try that in the morning. how difficult is it to take the carb off and put it back. any speical tools needed other than some wrenchs. what is the best process of cleaning it. im trying to read the therads but i really dont know much. im very glad to have found this site
thanx justjim
post #4 of 6 (permalink) Old 10-31-2009, 08:44 PM
Simple Solutions
seebeeare's Avatar
thanx justjim
its more like a chinese puzzle in and out be patient... leave the boot on the rear head and leave the boot on the front carb..
I find when installing a pry bar works good to set the carbs back in the boots ... the first time is tricky and the second time is like butter...
there will be more chiming in with there how too's if your not ear shaved then use a wood handled something to wedge between the head and the sergetank (air chamber below the gas tank)
when cleaning do one side at a time ... that way u always have a refrence for how to put it back together ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #5 of 6 (permalink) Old 10-31-2009, 09:05 PM Thread Starter
justjim910's Avatar
prepair to laugh ....... boots?
post #6 of 6 (permalink) Old 10-31-2009, 09:24 PM
The Professor
lance328's Avatar
The rubber boots that connect the carbs to the heads.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
