question regarding cobra pipes and carb jet size - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-29-2009, 09:41 AM Thread Starter
Send a message via Yahoo to luigit
Bear with this newbie but i need a question answered as i am a little confused. I purchased a VN 750 1994 that had cobra pipes on it but the carb was never re-jetted. My question is 2 fold
1. is it necessary for me to replace the jets to compensate for the different pipes and
2. which jets should be in there
thanks
luigit is offline
post #2 of 7 (permalink) Old 10-29-2009, 10:43 AM
With just the pipes being swapped, and nothing done to the intake (ear shave) the stock jets should be fine.
post #3 of 7 (permalink) Old 10-29-2009, 11:26 AM Thread Starter
ear shave
I was planning on keeping the stock air filters and not shaving them (god that sounds weird). But suppose i go ahead and go the ear shave route, is there a recommended jet size the carbs should be?
luigit is offline
post #4 of 7 (permalink) Old 10-29-2009, 11:32 AM
fergy's Avatar
There is some information on "ear shave" in the Vulcan Verses forum off the main forum page. Lots of folks have done it, (I personally like the looks of the stock filter boxes) and if you wait a bit, Lance will probably chime in with the proper jet sizes for a shaved 750.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 7 (permalink) Old 10-29-2009, 11:38 AM
Give lance everything you know about the bike. Shaved, not shaved, Which exhaust & where you are geographicly (height above sea level). I think that's what he'll need.
post #6 of 7 (permalink) Old 10-29-2009, 11:48 AM Thread Starter
specifics
Geographically located in Florida
non shaved (stock filters still in place)
cobra exhaust
bike came with cobra exhaust already installed but unsure if it ever ran that way. the bike also came with the stock air filters (ears) in a box seperate from the bike. I believe the previous owner was intending to do the ear shave but not sure. I have sourced out a new "surge tank" and am leaning towards using the stock air filter setup unless someone can recommend not to and use KandN filters instead.
luigit is offline
post #7 of 7 (permalink) Old 10-29-2009, 01:58 PM
93VN750's Avatar
cobra exhaust
I have a surge tank that you can have, along with the other associated goodies since mine is already shaved.
Stock Pilot Jet 38, stock main jet 132.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
