Won't Start, gas comes out of the over flow line - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 48 (permalink) Old 10-28-2009, 02:06 AM Thread Starter
I just bought a 1986 750 and it won't start, after I try to start it I notice that there is fuel dumping out the over flow line. What could be causing that? Stuck Floats? Carbs need to be removed and cleaned? ....
Any help would be appreciated
jimdeforge is offline
post #2 of 48 (permalink) Old 10-28-2009, 05:11 AM
The Professor
lance328's Avatar
You have a stuck float or debris in the float valve, try tapping on the side of the carbs.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 48 (permalink) Old 10-28-2009, 05:12 AM
CWO3 Navy (Retired)
cliffhusn's Avatar
Has the bike been sitting for a long time? Get a can of Seafoam and put about 3 oz. in the tank and put some directly in the bowl. It is a miracle drug for tanks and carbs. Check the Verses out, lots of information there on this topic. You can get Seafoam at most auto parts stores for about $8-9 a can. This would be my first step, I'm sure others will chime in with sound advice because they've been through this same thing. I eventually had to have my carbs removed and cleaned but then the bike sat for almost 10 years without being run.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #4 of 48 (permalink) Old 10-28-2009, 01:21 PM Thread Starter
It has been sitting for a while, but there is Seafoam in it already. Considering Seafoam is an additive to make the fuel stable for storage and doesn't have any cleaning agents in it. I was thinking of doing what was suggested in the Versus thread for Cleaning Carbs, I can't post the URL in here because I haven't posted at least 5 times. But it is the one talking about Cleaning / Rebuilding Carbs. I'll try tapping the bowls and Carb Cleaner to see what happens, will let you know.
post #5 of 48 (permalink) Old 10-28-2009, 03:26 PM
flitecontrol's Avatar
Read the SeaFoam label! It can be used in injector cleaning machines and dissolves gum and varnish in carbs like kids eat ice cream!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 48 (permalink) Old 10-28-2009, 06:14 PM Thread Starter
Yeah, I didn't know that until today after I posted, oops
post #7 of 48 (permalink) Old 10-28-2009, 07:48 PM
Well, my eureka moment came when someone here posted that Sta-bil has a two year shelf life once it's opened. Says so on the label I never read. Guess how long BOTH my 3/4 full bottles of Sta-bil have been open!
"Black Beauty"
Old Blue
post #8 of 48 (permalink) Old 10-28-2009, 10:06 PM Thread Starter
Glad I could help I didnt' have any luck yet, I need to buy some gas line clamps to shut the gas off so I can open the bowl drain plugs to spray carb cleaner through the carb. Hopefully that will help, I will need to change the plugs also. Then I happened to notice that the right turning signal doesn't work (not the bulbs), will have to figure that one out with the trusty volt meter.
post #9 of 48 (permalink) Old 10-28-2009, 10:16 PM
Unless your petcock is defective, why can't you just disconnect the fuel line hoses at the petcock or carb and drain the carbs? The carbs "pull" gas through the central vacuum line on the petcock. If the engine's not turning over, there's no vacuum and no fuel flow. Should also be able to just turn petcock to "OFF" and prevent gas from flowing to carbs.
Get the iridium plugs, should be the last plugs you have to buy (NGK 7803 OR NGK DPR7EIX-9) and they give excellent cold and hot starts. Cheapest I've found is a little less than $5 each at ORileys.
"Black Beauty"
Old Blue
post #10 of 48 (permalink) Old 10-28-2009, 11:23 PM Thread Starter
There is no "OFF" on the petcock, only "RES", "ON" & "PRI". That was the first thing I thought of doing, but to no avail, it didn't work. I opened the drain for the bowl on one of the carbs and waited for a while to see if it emptied, the flow was steady. So then tried to clamp the furl line to that carb with a pair of forceps I have, that didn't work. So I figured I woudl get better clamps than forceps (made for this) and then empty that one carb, clean it with a Spary Can of Carb Cleaner (through the drain) and hope that works.
