Gas Overflow After Fill-up - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 10-13-2009, 10:09 PM Thread Starter
Love My Baby
rubyrick's Avatar
Tonight I filled up after riding home from work. Well, it's a real short ride home from the gas station, and when I got home I immediately garaged the bike. You might remember that I've noted my baby is riding a touch hotter after installing our VN750 radiator grill cover. So the temp indicator shows just past the thermometer icon, and I shut her off and put her in the garage. Ten minutes later I smell gas in the house, pretty strong. Go in the garage and it's real bad, with a small puddle of gas under the rear part of the engine. No active leak in sight.
My guess is that the tank was full, the heat was high and the gasoline vented through the gas cap or some other vent tube. If so, everything was working properly and I don't have a crack or leak to worry about. Anyone else have some insight on what it might be or if I'm missing something here? Thanks...
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #2 of 8 (permalink) Old 10-13-2009, 10:37 PM
flitecontrol's Avatar
Hope you don't have a natural gas hot water heater anywhere near your garage!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 8 (permalink) Old 10-13-2009, 10:40 PM
Simple Solutions
seebeeare's Avatar
it doesnt even have to be hot for this i notice it everytime i get a lil to much gas and have to run into the store .... this drip happens all the time ... thats why my chosen gas stations are 15 miles from my house or work ...
Moving into the sticks so my gas station is gonna be more like 40 lol ... thinking about stashin an emergancy gas can in the bushes on the side of the road half way lol
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #4 of 8 (permalink) Old 10-14-2009, 12:39 AM Thread Starter
Love My Baby
rubyrick's Avatar
Excellent point, even though it sounds funny.
I think I filled up too high to the brim of the neck of the tank. Plus I've been running a bit hotter than I used to. Need to let my baby cool off before putting her into the garage.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
post #5 of 8 (permalink) Old 10-14-2009, 12:57 AM
dirtrack650's Avatar
My bro's Triumph (900 triple) does this in warm to hot weather. We were riding in 90 degree heat this summer, stopped for gas and to hydrate ourselves. While sitting on a bench enjoying some iced tea, his bike started squirting gas out the overflow tube. The gas cap had to be removed to prevent the flow from restarting due to sealed fuel systems and expanding gases on newer bikes. BTW, that Triumph engine runs lean and much hotter than our VN's.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #6 of 8 (permalink) Old 10-14-2009, 02:39 AM
Simple Solutions
seebeeare's Avatar
a trick my buddy did for his garage is he installed a bathroom exhast fan in his garage and wired it to the automatic light on his garage door opener so it shuts off after a couple minutes and gets the exhast smells out of his garage ... kinda not related ....
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #7 of 8 (permalink) Old 10-14-2009, 06:47 PM
Page 28 of the owners manual:
"Never fill the tank so the fuel level rises into the filler neck. If the tank is overfilled, heat may cause fuel to expand and overflow through the vents in the tank cap"
Many bikes now when you open the gas cap , have what looks like a metal can with a nozzle hole in the bottom recessed about 2-3 inches inside the tank. ...you only are supposed to fill the tank till the level reaches the bottom of the "can"...which can be a bit tricky.
I know some folks get a bit OCD'd when filling the tank , some go as far as to put the bike on the centerstand...rationalizing that you can shove more fuel in then. But unless you are traveling on the bike there is no reason to fill it so much. Keep in mind that gas draining out the vent hose ends up hitting the ground .......right in front of your rear tire. And if you ever found yourself riding over some spilled fuel, you know how slick the road suddenly becomes.
I agree that the fuel on your garage floor is more than likely draining from the vent hose, but given the recent post with the bike that caught fire...I would keep an eye on it for a few days to make sure it is not someting else. Fuel leaks are not something to disregard.
post #8 of 8 (permalink) Old 10-14-2009, 11:05 PM Thread Starter
Love My Baby
rubyrick's Avatar
Thanks KM, I appreciate your concern and the logic of your post. I've been watching it VERY carefully and it appears so far to have been an isolated case. Took the seat off today to make sure there wasn't any fuel spilled into the battery compartment or surrounding areas. Most likely the biggest factor was my filling to the brim, which I don't normally do. But also I've been concerned that I'm running a bit hotter since installing the new grill cover. Even at night my temp gauge is a bit higher than it used to be. And now this incident.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
