Another petcock question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-07-2009, 01:24 PM Thread Starter
flitecontrol's Avatar
Discovered a while back that when I turned the petcock to Reserve, the carbs get no gas, even on a full tank. Figured the stealership that did a crappy job of Kreeming the tank may have coated the reserve screen. When I pulled the petcock to clean the tank, there was nothing on the petcock and the screens were intact. So, is one of those $24 ebay petcock rebuild kits gonna fix my reserve problem? Anybody ever have this problem and how did you fix it?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #2 of 7 (permalink) Old 10-07-2009, 09:52 PM
If you're comfortable with taking the petcock apart you can easily check the flow path from the reserve screen or the main screen to the petcock valve. Just take the two screws off by the lever and pull the pieces out one at a time. The lever comes out 1st and it will have an O-ring on it, then there is a spring washer. The rubber seal will stay in most likely.
The rubber seal has a tendancy to dry rot and it will come apart in large enough pieces to block a port. Look for trash in the holes, use lacquer thinner or Wesleys Bleach white to clean it up. The rubber seal is only about $12 at Ron Ayers, use a little grease on the O-ring when you put it back together.
You shouldn't have any problems checking it out.
AceMcgyver is offline
post #3 of 7 (permalink) Old 10-08-2009, 12:18 AM
The Professor
lance328's Avatar
If you are going to remove it to clean you may as well replace ALL wearable parts.
43028-1033 DIAPHRAGM $9.51
92055-1085 "0" RING,FUEL TAP LEV $1.83
11009-1188 GASKET,FUEL TAP $2.29
51039-003 "O" RING, FLANGE $2.29
$15.92 + shipping @ cheap cycle parts
The diaphram does include the small o-ring
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 7 (permalink) Old 10-08-2009, 08:15 AM Thread Starter
Thanks guys. Out it comes.
"Black Beauty"
Old Blue
post #5 of 7 (permalink) Old 10-08-2009, 03:38 PM
aka Smokymtnvulcan
Ablerider's Avatar
I did the rebuild so anyone can do it! Make sure you "clean" out the body, I used carb cleaner............and, don't forget to take a spritz of DW40 into that little check valve where the vacuum line plugs in. If you don't, the whole rebuild is for naught :-) After you rebuild the petcock, lock lips with the vacuum check valve and suck on it. You should hear the plunger thingy or at least feel it activate. Applying the same type of vacuum to the two fuel ports, should get nothing, remembering to plug the other with you finger while applying vacuum to the other.
VROC #28359 Murphy NC
Patriot Guard Rider
US Army (Retired)
NC Law Enf (Retired)
VN750A3 New RR, New Stator, New Tires, Cleaned Carbs, New Choke Cable, Degoated and Marbled, replaced ACCT with MCCT, Custom LED Signals F&R, Custom Luggage Rack.
Did Tail of the Dragon in 1972 and again 07/2011
I like pipes I can hear!
I wear leather so I won't hurt too bad!
I wear a half helmet so I can see and hear better!
Not a poser, not an outlaw biker, JUST ME!
Ablerider is offline
post #6 of 7 (permalink) Old 10-12-2009, 12:03 PM Thread Starter
The Vulcan Lip Lock? Anything like a mind meld?
"Black Beauty"
Old Blue
post #7 of 7 (permalink) Old 10-12-2009, 12:09 PM
Go to the vulcan star trek verses for info. lol
