My Big Tank - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 28 (permalink) Old 10-02-2009, 04:22 PM Thread Starter
Simple Solutions
seebeeare's Avatar
My Big Tank
As a lot of u know last year i did a mod for a largerr tank anf it was crushed by an accident ... well i've been bored latly and decided to see what i can do... So to start this thread i decided to just take comparison pics... im working on the mounting system and when i get that ironed out i'll post pics of that... my tank has a nice dent by the gas cap and im working on filling that.. all in all i hope to have this tank ready to install befor all my parts get here for the engine stuff 'm doing...
I dont know the year and model this tank was off of but im guessin its off a vulcan 1500 ,
Issues befor tank kind sat on the ears befor and i rotated both ears 180 degrees and the tank would fit (rub on ears but fit)
Also the forks will hit the tank at full turn so u turns became tougher all adjustable with riding style and practice...
petcock off of old tank the same and the sending unit is the same (the wires are a little short ti reach the harness)
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #2 of 28 (permalink) Old 10-03-2009, 12:34 AM
GIMPYRDR's Avatar
Yes keep us posted. I have given a lot of thought to trying to find a larger tank. Dennis Kirk and JP Cycles have started carrying custom tanks in different capacities, but I don't want to give the gas gauge. The customs don't don't have the bung for the float and I am not a metal worker by any means to be able to adapt one to our bikes and not cause a major screw up. Don't have the money to throw away on trial and error.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #3 of 28 (permalink) Old 10-03-2009, 01:33 AM Thread Starter
Simple Solutions
seebeeare's Avatar
gas sending unit is the same on these tanks ... iv'e had it on befor and really all u need is hoses and a few dollars in hardware and materials...
just need to come up with something for the speedo hole thinkin of makin a glove box or charging station for phone or ipod....
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #4 of 28 (permalink) Old 10-03-2009, 08:09 AM
Looks like it fits on there pretty good.
Did ya ever do any kind of actual comparison as to how much turning radius you lose?
Wouldn't be too tough to get something welded to the turn stops to stop the forks from hitting, if it itsn't too much you lose.
post #5 of 28 (permalink) Old 10-03-2009, 11:06 AM
Concert connoisseur
wib714's Avatar
it'd be cool if you could fab a couple indentions in the tank on each side to get your turning radius back.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 28 (permalink) Old 10-03-2009, 11:20 AM Thread Starter
Simple Solutions
seebeeare's Avatar
turning radious ...
hthe forks will come back and touch the tank on both sides u lose probably an 1/8 inch on each side was gonna tack in a couple small nuts into the exsisting fork, there will be a lot more pics of the following steps and final look
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #7 of 28 (permalink) Old 10-03-2009, 11:23 AM
GIMPYRDR's Avatar
The speedo hole is an idea. Not enough room on the handle bars because of my windshield mounts. Would definitely like to put some electronic accessories on it.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #8 of 28 (permalink) Old 10-03-2009, 11:44 AM
dirtrack650's Avatar
How about relocate your speedo to the new hole and trash the tach for a cleaner look up top?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #9 of 28 (permalink) Old 10-03-2009, 12:01 PM
DT
If you can find a dash for an eighties model HD Lowrider Or superglide they had the tach and speedo both mounted in that hole one in front of the other and they were standard size gauges close to our speedo and tachthere was a mounting base and cover for the housing,I also like your idea for your electronics.
post #10 of 28 (permalink) Old 10-05-2009, 09:30 AM
dagmar's Avatar
the tank looks to be off of a 1999-2003 VN1500 Classic
I have been thinking about swapping out my tank for a larger one. how many miles can you go before you have to fill up with that tank
'99 VN750
12998 miles - 2009
Completed:
Custom seat (steal tractor seat cut down to give more leg room), 10"X12" 1/8" steal plate Rack., 18" drivers back rest, custom Highway bar, coastering.
Future:
5 gal tank.
dagmar is offline
