running rough in 5th - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-30-2009, 10:58 PM Thread Starter
Concert connoisseur
wib714's Avatar
I think this may be a similar problem to the post a few threads down called running fine til highway speeds. bike runs fine but wants to bog down a bit in 5th gear, 1-4 are fine but when i hit 5th it bogs. will do it for a few minutes and then smooths out, not sure if its fuel or air starved. also when it seems to do this the lights seem to get a lot brighter, when it smooths out they go a little dimmer. I do notice the headlights are much brighter since my rr and stator rebuild though. but what would cause it to run rough in 5th only?
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 7 (permalink) Old 10-01-2009, 09:33 AM
fergy's Avatar
Mechanically, or electronically, it doesn't make any sense that 5th gear could cause an electrical issue. Have you tried to run the same rpms in 4th for a long stretch and see if it acts similar? If it is speed/wind related, then it could be a loose connection of some sort, and I'm reaching here, but for instance if your coil power wires were not making good contact and the bike was losing the rear coil for instance, at a certain speed, maybe the lights would get brighter because of less draw by the coil that was missing??????? Really guessing, but it would be helpful to have a lot more specific information on this issue!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 7 (permalink) Old 10-01-2009, 04:53 PM Thread Starter
Concert connoisseur
wib714's Avatar
really not sure if the two symptoms are related but it almost seems like my bike has 2 levels of high beams that I cant control. its off and on. so is the sputtering and last night was the first time i noticed it at the same time, could be coincidence. A couple times after I started it though it almost seemed like it was out of gas, sputtered real bad and died, had to turn the petcock on prime, restart it and it ran fine for about 2 miles till I got on the highway and started sputtering in 5th for a few miles and smoothed out again then ran fine again for a few days.
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 7 (permalink) Old 10-01-2009, 08:12 PM
Now what
Ironman's Avatar
There's a breather tube that is suppose to be held by a slotted channel in the right side filter cover (ear). I tried to take a couple of pictures of what it should look like. I put a circle around the tube in question. It's the one in the middle of the picture. If it's not there, it may be sitting on top of the cylinder kind of flapping in the breeze. It needs to sit in the channel, but not bottomed out in it. I experienced the same feeling of running out of gas on the freeway and found the tube in the wrong place.
Name:	Breather tube 2HL.jpg
ID:	2329   Click image for larger version
Name:	Breather Tube HL1.jpg
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #5 of 7 (permalink) Old 10-01-2009, 09:12 PM Thread Starter
Concert connoisseur
wib714's Avatar
thanks ironman, I'll check it out. I was kinda leaning toward an air issue or vacuum. was gonna clean my filters and see if that helps oo!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #6 of 7 (permalink) Old 10-02-2009, 12:15 AM
95VN750's Avatar
Does this sound like a hot wire grounding out or am I just reading too much into this?? I would look into the head light and see if there is a direct power short...
1980 440LTD
1976 KZ900
1995 VN750 19,500 miles ( start of '08 season ) All mine!
Can't have too many Kaws!
95VN750 is offline
post #7 of 7 (permalink) Old 10-02-2009, 09:21 AM
fergy's Avatar
It might be a coincidence that the light is dimming and brightening along with the sputtering. Could be two un-related issues, especially if the light seems brighter when the engine is sputtering. I would treat it as two separate issues right now and start checking filters, vacuum lines etc. to see if you can find the cause of the engine problem. Also check in the headlight case for loose, worn or corroded wiring to look for the headlight issue. Check battery connections and grounds.
Check coil wiring, plug wires, caps etc. too for bad connections or cracks etc.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
