Anyone wanna check my diagnosis? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 09-28-2009, 05:00 PM Thread Starter
Adventuregeek
Tiki Mon's Avatar
My guess: stuck float valve in rear carb.
Cranked 'er up Saturday intending to ride. Started, ran a little rough, got rougher... wouldn't run without the choke on. In fact, it only runs with the fuel valve OFF, if I turn it to ON, it quits.
Front plugs are good. Rear plugs are wet with gas. Oily fuel drips from the rear exhaust joint at the block when it's running. Major gasoline smell out the back (the cycle, not me). It will idle, but rev it and it backfires and blows out a puff of smoke.
Of possible interest: about 25 miles ago, it quit on me at an intersection. Wouldn't idle, but would rev slowly higher and higher until I cut the switch. I finally spotted that the rear carb air boot had slipped off. I replaced and tightened it and the cycle ran fine for the rest of the trip.
Any other likely suspects besides the float valve?
Thanks!
-Tiki
Laissez les bon temps rouler!
Coastered, R&R relocation, MCCT's, Koso mirrors, Memphis Shades windshield, Mutazu GA hard bags, big monkey in the saddle. ATGATT: Olympia AST hi-viz jacket, Recon 2 (convertible) pants
Tiki Mon is offline
post #2 of 9 (permalink) Old 09-28-2009, 09:39 PM
my guess would be the same thing. the float is stuck open so it is dumping fuel down the carb.
6204 is offline
post #3 of 9 (permalink) Old 09-28-2009, 10:00 PM
flitecontrol's Avatar
Tried tapping on it with a screwdriver handle?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 9 (permalink) Old 10-13-2009, 03:55 PM Thread Starter
Adventuregeek
Tiki Mon's Avatar
Yep, stuck float.
Dumped half a can of Seafoam in the tank, ran it every so often for a minute to run the solvent through. Hammered on the carb, shot carb cleaner up the bowl drain. After a day of that and an oil change (gas got past the rings) it was behaving more normally. Took it for a 50-miler and it was back to normal when we got back.
I'll have to pull the carbs someday, I suppose, but NOT YET! :-)
Tiki Mon is offline
post #5 of 9 (permalink) Old 10-13-2009, 04:26 PM
The Professor
lance328's Avatar
Get some inline filters on before more debris gets in the carbs.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 9 (permalink) Old 10-13-2009, 06:16 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Originally Posted by Tiki Mon View Post
Yep, stuck float.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #7 of 9 (permalink) Old 10-13-2009, 09:16 PM
Love My Baby
rubyrick's Avatar
Hey Jay, powerful message! Sometimes putting off preventative maintenance can have explosive consequences.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #8 of 9 (permalink) Old 10-14-2009, 09:33 AM
fergy's Avatar
I would suggest that for the time being, you get used to turning off the petcock when you park the bike. We all should probably be doing that anyway since you really never know when a float valve will decide to stick open and if the petcock happened to be bad, you could have a nasty situation on your hands. Think about the photo above... If that would have happened when he got home and pulled her into the garage....
An ounce of prevention could save the cost of a bike, or even a house...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 9 (permalink) Old 10-14-2009, 04:41 PM Thread Starter
Adventuregeek
Tiki Mon's Avatar
Yup, I shut off the fuel when I stop. Believe me, I've seen enough vehicles burn to be paranoid about fuel leaks.
Looking for a small extinguisher to carry too. I watched a few vehicle fires start, and you've only got a couple of minutes at MOST to prevent a total loss. On a cycle, I imagine it's pretty quick.
Tiki Mon is offline
