What to do for carb cleaning? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-25-2009, 01:02 PM Thread Starter
HI everyone again,
I pulled off the carbs and now i am cleaning them what do you suggest is the best products to use and should i soak them in anything? Or just spray? How about the rubber parts are they safe to soak in any carb cleaner?
blackneckphi is offline
post #2 of 7 (permalink) Old 09-25-2009, 01:38 PM
STUMPYSKAW's Avatar
Howdy, I use Barrymans Chem dip, it comes in gallon cans at your local auto parts retailer, this stuff isn't as strong as it used to be and I have soaked several carb in it and haven't had any prob with the plastic parts. Don't put any of the rubber parts(diaphrams, O rings, ect) in this stuff , it will affect them. for spray I use Gumout carb cleaner from wall- mart. It's cheep( I go through at least a case a month if not more in my shop) and does a very good job of cleaning. after you dip the parts rinse them with water. spray carb cleaner through every hole you can see. you can't be to clean. compressed air is a plus too. just haller I f you need any help. lots of smart folk on this site.
"DAISY" 85 VN 700 19K
Owned since 09/12/09
Done list
Metal radiator drain plug
Removed exhaust baffles
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
VN900 seat on my VN700
https://www.vn750.com/forum/showthread.php?t=12903
Debaffling my stock pipes
https://www.vn750.com/forum/showthread.php?t=12756
STUMPYSKAW is offline
post #3 of 7 (permalink) Old 09-25-2009, 03:05 PM
750Doug's Avatar
Inspect all small holes/passages carefully and with a light if you can, and if you have any doubt, clean 'em again. Better to do it twice while they're already off the bike, than have to install/remove/clean again.
750Doug is offline
post #4 of 7 (permalink) Old 09-25-2009, 03:45 PM
fergy's Avatar
Also, when you shoot that cleaner into those little holes, wear safety glasses! Some of those little holes connect to other little holes and some of them little holes will be pointing right at your eye! I wouldn't know, but it's what I've been told...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 7 (permalink) Old 09-25-2009, 03:58 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Might try this...
https://www.vn750.com/forum/showthread.php?t=12341
Originally Posted by blackneckphi View Post
HI everyone again,
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #6 of 7 (permalink) Old 09-25-2009, 04:39 PM
STUMPYSKAW's Avatar
Originally Posted by jthill524 View Post
Sorry forgot to address safety issues, it might be all the carb cleaner in my eyes gettin to my brain.HE HE HE. yes it hurts,and yes crying will wake it feel better.
I'm sure boiling lemon juice would hurt in the eyes too. I'll have to try it (hopefully not in my eyes). the new barrymans chemdip aint worth the can it comes in anymore. I have some old carbs I'll have to try vineger on.
Done list
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
post #7 of 7 (permalink) Old 09-25-2009, 05:49 PM
The Professor
lance328's Avatar
Advance Autoparts sells the good Gunk Carb Dip, same stuff as 10 years ago.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
