"Air mix screws" - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-24-2009, 07:03 PM Thread Starter
ACS
"Air mix screws"
Hi everyone,
I have V&H cruzers, and I'm experiencing the popping/backfiring.
In the Vulcan Verses, the "air mix screw" is mentioned several times. I looked through chapter 2 of the Kawa MSM, and I didn't find the words "air mix screw." What are these screws called in the MSM?
Thanks,
ACS
USMC OIF Veteran
Student of Biochemistry at the University of Michigan
ACS is offline
post #2 of 4 (permalink) Old 09-24-2009, 07:13 PM
Crobins365's Avatar
In Clymer's they're labled as "pilot adjust screws." They may also be called "fuel mixture screws" since they regulate the balance of fuel/air going into the carbs. They're located under the vacuum port (brass nipple) on each carb - if you have trouble seeing 'em, could be that yours are still covered by the lead plug that has to be put over 'em at the factory.
C
Crobins365 is offline
post #3 of 4 (permalink) Old 09-24-2009, 10:40 PM Thread Starter
ACS
Got it. Thanks.
Now I just need to buy a smaller screwdriver.
-ACS
USMC OIF Veteran
ACS is offline
post #4 of 4 (permalink) Old 09-25-2009, 10:41 AM
fergy's Avatar
Yeah, the names for them are endless, but "air mix screws" is the farthest from the truth. They only regulate fuel for the idle mix.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
