carbs? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-20-2009, 04:41 PM Thread Starter
carbs?
Hi everyone,
So i decided to take my motorcycle apart to fix the head gasket but disassemble the gas tank .... so now i am on the carb. I cant get the carb off the motorcycle someone help i disconnected the throttle and choke cables. Am i suppose to separate the carbs? Or do they come out in one big piece?
blackneckphi is offline
post #2 of 7 (permalink) Old 09-20-2009, 05:46 PM
flitecontrol's Avatar
This manual should help. It's a big file BTW. http://www.tocmanufacturing.com/File...nd%20Parts.pdf
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 7 (permalink) Old 09-20-2009, 08:52 PM
Crobins365's Avatar
The carbs come out the right side (as you're sitting on it) of the bike. Leave the boot for the front carb on the engine block; for the rear carb, take the boot with the carbs. You'll want to lift up HARD on the airbox to clear the way to pull the entire unit (two carbs) out. It's kind of a lift-up-tilt-to-the-left-pull-through-turning-slightly-to-the-rear-of-the-bike motion - and it's not usually very smooth. Seriously, though, if you can get someone to give you a hand, one of you needs to lift up on the airbox and your path will be much, much clearer.
C
Crobins365 is offline
post #4 of 7 (permalink) Old 09-21-2009, 12:17 PM
Authority84's Avatar
First 2 times I pulled my carbs was out the right. Third time out of frustration I managed to pull them out of the left... I screwed up though and pulled both boots to manage it. Took forever to get them back in the right position. I also found that if you pull a little on the throttle lever on the bottom of the carbs when they start to catch it makes it slide out a lot easier, could just be I had to re pull them so many times to reposition those boots that any extra metal was scrapped out of the way....
Good luck man, like they always say once you have had them out it only gets easier the next time.
1993 Kawasaki Vulcan VN750 <To Be Named Later>
Purchased Used on 05/09/2009
11,681 Miles...
Dade City, Florida
Iridium Spark Plugs
New Shinko 230 Tour Masters
110/90/19 Front 150/90/15 Back
Carbs Cleaned 06/22/09
Spline Lube 6/29/09
1992 Kawasaki Vulcan VN750 <Parts Bike>
Authority84 is offline
post #5 of 7 (permalink) Old 09-21-2009, 05:20 PM Thread Starter
Thanks everyone esp Crobins365 for the lift up tilt... i got it out now. I am gonna clean the carbs and then attack the engine i hope this runs when i put it all back together
post #6 of 7 (permalink) Old 09-21-2009, 08:26 PM
Crobins365's Avatar
Give a holler when you're ready to put it back in. Definitely less of a technique description than encouragement to find your inner zen.
C
post #7 of 7 (permalink) Old 09-21-2009, 09:16 PM
Thanks, I needed that! Still grinning!
"Black Beauty"
Old Blue
