Gas Tank Rust Removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-19-2009, 06:29 PM Thread Starter
93VN750's Avatar
Is there a good way to remove the rust from inside the gas tank? Mine has been empty for almost 2 years and there is some surface rust that has formed.
Would rather deal with it now while tank is bare metal than after it is painted.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 10 (permalink) Old 09-19-2009, 07:04 PM
flitecontrol's Avatar
Fergy used an acid bath and there is a post in the Verses about using a battery charger that I plan on using. Someone else used vinegar and salt.
Seems there are lots of ways to skin a cat or clean a tank.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #3 of 10 (permalink) Old 09-19-2009, 09:18 PM
Link to Verses:https://www.vn750.com/forum/showthread.php?t=1152
https://www.vn750.com/forum/11-vn750-general-discussion/9127-top-ten-items-you-would.html
post #4 of 10 (permalink) Old 09-19-2009, 10:36 PM
G3P0's Avatar
I need to do this, workin on paint removal tonight, planning the battery charger method. I have the petcock and sender out, any suggestions on what to use to seal bottom while performing the electralosis method of rust removal?
85 VN700 Project Bike
Earshave
Mustang Seat
Custom grill cover
Busted Engine... removed, split, waiting on parts
Cleaning up & painting the rest
Parts still needed... wanted...
11" shocks, or one stock
Aftermarket exhaust... eventually
Extended forward controls or custom hwy peg mounts for my cramped legs...
G3P0 is offline
post #5 of 10 (permalink) Old 09-19-2009, 10:46 PM
3 ways i know of to remove rust.
1. electrolosis
2. mild HCl acid bath.
3. shake it around with BBs
6204 is offline
post #6 of 10 (permalink) Old 09-20-2009, 12:47 AM
Fergy used good quality duct tape for the acid procedure. Think I'll go that route too.
"Black Beauty"
Old Blue
post #7 of 10 (permalink) Old 09-20-2009, 01:44 AM
dirtrack650's Avatar
I did my XS650 a few weeks ago with vinegar and BB's. Tank was in poor shape on the inside, outside the paint looks great for a 34 year old bike. I was please with the result but the electrolosis sounds like the way to go. I used duct tape over the petcock holes with no leaks.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #8 of 10 (permalink) Old 09-20-2009, 05:20 AM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
https://www.vn750.com/forum/showthread.php?t=12303
Here's a few Ideas.
Jon
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #9 of 10 (permalink) Old 09-21-2009, 11:12 AM
fergy's Avatar
I won't rag on the other methods used here, but I like the acid method primarily because it is fast, and the most effective I have seen. Whole process takes about 3 hours. This is from a tank that was like brown mud inside from all the rust, to a bright shiny silver, rust free interior. If I had only shot before and after photos!
Copied from a previous post:
There are different methods used to clean the rust out of a tank. My favorite is using acid. This makes some folks queasy here, but it does a really good job, is cheap, and pretty quick, compared to other methods.
After removing the tank, you need to flush it thoroughly with your garden hose. Really work hard to get everything you can out with water. You have to remove everything, petcock, fuel level sensor, gas cap etc. and tape up every opening with good quality duct tape. Use a handful, maybe 50 or so, small 1/4" steel nuts (not 1/4 inch threads, but small steel nuts that are about 1/4" outside diameter) and dump them into the tank. Carefully, pour about 12 oz of muriatic acid (they sell it at pool supply stores, or Home Depot) into the tank and tape up the gas cap hole and shake the tank vigorously for about 10 minutes. Keep the garden hose handy and rinse off any leakage immediately. (wear old clothes, rubber boots, rubber gloves and eye protection, maybe a smock if you have one) The acid and nuts will eat the rust off the tank inside. You might have to vent the pressure off the tank by lifting the tape around the gas cap hole every once in a while. You'll know when it bulges the tape. Keep rinsing the outer surface immediately if any acid leaks out around the tape. It will be the color of mustard so it's not going to be hard to see. After 10 minutes or so, remove the tape and let the acid drain from the bottom of the tank, into a plastic bucket full of water that you have added about a cup of baking soda. The baking soda will neutralize the acid. The writeup said to pour the acid on a patch of old concrete that you don't mind staining to neutralize it, but I prefer the baking soda method. Then you can pour the mixture in a gravel or dirt area and it will be fine. This acid will etch the metal and your surface will be clean and rust free. Now rinse the tank very well, flushing it with the hose and shake it to make sure you get all the acid rinsed out. You can use a telescoping magnet pick up tool to get all the nuts out of the tank. (make sure the nuts are steel!) Then tape it back up and pour two bottles of naval jelly into the tank. You need to do this immediately after you get the acid flushed out, as rust will start to form immediately on the untreated metal. Shake the tank for a minute or two and then let it set for 30 minutes, then shake it again. Do this for 2 hours. Then rinse the naval jelley out by flushing it with the hose. Once clean, dry off the outside and rig a blow drier at the warm, not hot, setting and let it dry the inside of the tank. The phosphoric acid in naval jelly will treat the metal and make it resistant to rust. My tank has been silver inside since I used this to clean it. (I did this on my KZ1000P when I first bought it, and I sold it 1.5 years later and the tank was still nice and silver inside, no sign of rust!)
It's messy to do, but it works very well, and doesn't leave a film inside the tank that you might have problems with later. This method might seem a little radical, and some of you might prefer not to mess with the acid, but it works very well.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #10 of 10 (permalink) Old 09-21-2009, 01:59 PM
Most of the rust in my XS tank was on the sides and top so I shook upside down.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
