Not a 750/but I trust the guru's on this forum. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-28-2009, 02:17 PM Thread Starter
96 Vulcan 1500 Classic - Carb CVK40.
Been a week and 5 days of problem free riding since I put the carb back on the bike and the same ole' problem I had last month resurfaced this morning. Felt her stumble at 20mph going through town and she smoothed out on the back road at speed. Pulled into the lot, shut her down and pulled the right side aircover. Fuel bubbling from the air intake jets and in front of the butterfly flooding.
What I've done in the last three weeks since this problem started.
Brokedown carb, fully cleaned three times
Float replaced
Needle replaced
Fuel level set at 1mm below mating surface/using service fuel level tube
All diaphrams inspected/no holes or cracks/good seals
Tank cleaned
New fuel filter
Petcock inspected and screens cleaned
Every vent/vacuum/fuel line replaced
Tank vents inspected and operational/no pressure build in the tank (hissing/whistling or pressure when I pop the cap)
Its like some pressure is pushing the fuel level up/it seeps out the air intake and venturi vents past the butterfly into the cylinder. It will do this for about 15 minutes after the bike shuts off then stops (when engine cools down).
I'm considering a fuel pump bypass just to see if that may be the issue.
Also noticed some oily junk in the air switch where the crank vent hoses run. When I manually acticated the diaphram, oily gunk spit out of the tube where the carb plugs in. If that switch is bad, is it possible that it could create vacuum where it t's into the top of the carb which is "pulling" fuel up????
Grabbing for straws here.....I'm determined to track and fix this problem.
Cassack is offline
post #2 of 5 (permalink) Old 08-28-2009, 02:20 PM Thread Starter
P.S. I have posted the same on the VROC main site. Just looking for additional recommendations....
Cassack is offline
post #3 of 5 (permalink) Old 08-28-2009, 02:59 PM
fergy's Avatar
Someone on VROC had this exact same problem a month or so ago. Don't know if I can find it but I'll look and try to point you to it... (was it you?)
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 5 (permalink) Old 08-28-2009, 03:08 PM
fergy's Avatar
Never mind, it was you... Sorry. I was hoping you had this fixed by now. I don't know enough about the older 1500's to be of any help. But the VROC group has a bunch of guru's on that carb. someone will eventually help ya.
Could it be that your float bowl level is set too high, allowing the expansion from heat to bubble over? I know you said 1mm setting, but maybe it should be a little lower???
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #5 of 5 (permalink) Old 08-28-2009, 03:40 PM Thread Starter
It was likely me Fergy. It started about a month back and I posted a couple of questions on the VROC site then. Thought I had the issue knocked out but its just haunting me now.
I started with the float level at the mating surface per the book on the first time. Ran good for two days then started again. Last time I took it down to 1mm below and it was fine for a week (rode 80 miles daily for the week on the commute). I can take it down to 2mm below and still be within the book specs.
Cassack is offline
