advice on fuel petcock (?) needed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-27-2009, 10:11 PM Thread Starter
Send a message via Skype™ to wouter
So I'm finally starting to do some maintenance and replacement jobs on my recently acquired vn750. First job is the cooling system, that hasn't been functioning well (one of the hoses tore and I got sprayed with coolant last saturday). Got it all off now and am cleaning it (radiator, thermostat etc) and replacing the hoses.
The issue is, that on taking off the fuel tank, I noticed that one of the vacuum leaders is leaking fuel. I understand that the two lateral pipes that com out of the tank are vacuum pipes, the middle one is the fuel one. So one closing the fuel valve there shouldn't be leaking fuel, right ?
I'd appreciate an explanation on what is happening here, and the procedure to be followed. Thanks in advance !
wouter is offline
post #2 of 9 (permalink) Old 08-27-2009, 10:37 PM
flitecontrol's Avatar
You've got the vacuum and fuel lines confused. There are two fuel lines (one to each carb), and one vacuum line. Probably ought to replace all of them at the same time.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 9 (permalink) Old 08-27-2009, 10:46 PM Thread Starter
ok, I'll check it out
Hmm - thought I got it right from the Clymer manual. Thanks for the quick reply !
wouter is offline
post #4 of 9 (permalink) Old 08-27-2009, 10:53 PM
Well, I've been wrong before! Looking in my Clymer and Kawasaki manuals now.
Update: Clymer, page 275, 4. disconnect the fuel line (figure 83) from the fitting on each side of the fuel cutoff valve.
Yep, two fuel, one vacuum.
"Black Beauty"
Old Blue
post #5 of 9 (permalink) Old 08-27-2009, 10:56 PM Thread Starter
but what you say makes sense
two carbs two hoses makes sense - but then, with the fuel valve closed, the valve pipes shouldn't leak should they (it's one of the pipes that leaks, not the hoses) ? Should I replace something ?
wouter is offline
post #6 of 9 (permalink) Old 08-27-2009, 11:07 PM Thread Starter
Hmm - good lesson for a first time mechanic. But it's fun and the bike is great. Thanks !
wouter is offline
post #7 of 9 (permalink) Old 08-27-2009, 11:08 PM
Not sure what you are calling the valve pipes. Do you mean the metal hose fittings (nipples) on the fuel shutoff valve? If one is leaking, could it be cracked? If both are leaking, the valve may need to be repaired.
"Black Beauty"
Old Blue
post #8 of 9 (permalink) Old 08-27-2009, 11:09 PM
The Professor
lance328's Avatar
The outlets on the petcock are press fit, use a c-clamp to to press back into the petcock.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 9 (permalink) Old 08-28-2009, 11:41 AM Thread Starter
Ok, I'll check it out. Lance, I send you a pm on coaster and r/r kits.
wouter is offline
